Battery Level Meter
Add 32 to the value for channel 002 on module 07 as seen here: http://wiki.ross-tech.com/wiki/index...d_Front_(High)
Is there anyone out there that can walk me through this method of coding step by step?
The most complicated thing that I have done with my VCDS to date is change the rear brakes.
a check box from Hidden Menu will enable the battery meter from MMI
Enabling the Hidden Menu in MMI high (2G): (Only for Navigation Equipped Cars)
[07 - Control Head] `
[Adaptation - 10] -> Channel 8 -> Change 0 to 1
Use this hidden menu at your own risk.
To get to the hidden menu, press and hold Car & Setup for about 6 seconds ..... and once in tread VERY carefully
Caution: Keep away from the "Bootloader"
Thanks for the info. I have 3G Low (2009 Avant)
seinfieldbutsad
A4 (B8 Platform) Discussion
05-18-2019 05:57 PM
Silver_Solid
07-15-2017 02:13 PM
1FastRS4
09-02-2003 03:22 AM
