Best way to drain coolant for 2007 S6?
#11
1. Disconnect the coolant return line.
2. Attach a flexible tube long enough to lead the extension to the floor, into a bottle.
3. Remove the coolant tank and tilt it up above the disconnected return line height. Coolant from the tank will be evacuated to the bottle on the floor.
The following video will give you an idea.
https://youtu.be/7_UC5njIOuw
kelisko (04-14-2021)
#12
#13
#16
#17
Maintenance can be a struggle. So many things require you to pull the engine like O2 sensors. It’s a reliable engine though.
#18
Haha, good points but it had better be a reliable engine if you have to pull it for even O2 sensors!! Although, with an engine like that you don't pull the engine from the car, you remove the car from the engine.
kelisko (04-15-2021)
#19
audi bug
25
08-12-2022 09:39 AM
arjun90
15
04-28-2015 06:53 PM
Blown Nogaro
9
07-15-2003 06:02 PM
