Black rear door triangular trim ?
1 - Window frame
q Removing:
Note
When removing the window regulator, the self-adhesive seal for the window frame must be renewed → Fig..
q Remove door trim. → Rep. gr.70
q Window frame removed from door together with window regulator → Chapter
q Door window -6- removed
q To remove, unscrew countersunk-head bolt -5- and detach window regulator from window frame.
q Installing:
q When installing, ensure that guide rail runs parallel to guide -arrow-.
q Tighten bolt -5- to 6 Nm.
2 - Seal
q
3 - Triangular trim
q Before removing, take out window frame and window regulator
q Unscrew bolt -4- and detach trim panel to side
4 - Bolt with washer
q 7.5 Nm
5 - Countersunk-head bolt
q 6 Nm
6 - Door window
Removing:
q Lower door window.
q Unscrew bolts -7- and detach door window from window regulator.
Installing:
q Insert window in window regulator.
q Screw bolts -7- loosely into window regulator, but do not tighten yet.
q Move door window upwards into window frame.
q Pull door window forwards into window guide on window frame at B-pillar and tighten bolts -7- to 4 Nm.
7 - Countersunk-head bolt
q 4 Nm
8 - Window regulator
q Door window removed
VWVW
Audi A3 / S3 / RS 3 MKII
01-29-2018 12:33 PM
feakara1
10-03-2006 01:16 PM
Crisqo09 T.O.
04-27-2003 07:47 AM
