A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Old 07-25-2016, 03:17 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C5) Brake Guides
Print Wikipost
Brake Fluid flush at Sears Autoshop?
Old 11-28-2009, 09:43 AM
am_ver's Avatar
Default Brake Fluid flush at Sears Autoshop?
I just found out that Sears auto does the brake fluid flush for $35. I just replaced the front and rear brake pads, and my 2 year brake fluid needs to be replaced May '10. Since it is only $35, I am tempted to do this flush now instead of waiting for May ($35 seems really reasonable to me). Does anyone know if it is ok for Sears to do this (as opposed to the dealer)? ok to use Sears brake fluid as opposed to Audi OEM?
Old 11-29-2009, 05:35 AM
mystrodo's Avatar
As long as it's Dot 4 fluid your ok..I see no reason sears can't do a simple flush but there is a procedure, find out exactly what they do to do a full brake flush.
Old 11-29-2009, 09:04 AM
KevinGary's Avatar
The fluid costs $17.95 at Blauparts, how can Sears make any money using the correct fluid and selling the entire service at $35?
Old 11-29-2009, 06:06 PM
Audiworld Senior Member
jefman's Avatar
Discounters think that way, lower prices and drive out the little guys. Increase market share then raise prices back up. Classic example, Duane Reade.
Old 11-29-2009, 08:09 PM
A6Gary's Avatar
Default Do the Sears techs know how to correctly perform the brake fluid flush???
Unless they have access to a Bentley Repair Manual or have been trained as a VW/Audi mechanic, I would doubt that Sears could do the job correctly for $35. The brake flush service requires a pressure brake bleeder plus know the recommended amount of fluid to bleed from each wheel cylinder (200 ml). Why don't you buy your own pressure bleeder for ~$35 and do the service yourself every two years?
Old 11-30-2009, 01:22 AM
killerwatts's Avatar
Default Do not use Sears
Under no circumstance should you take your Audi to Sears. I have a horror story out of this world about an incident with my Audi that occurred in 2007. I called them in advance and asked them if they could do the service (driver side front upper control arm a pretty simple job) and they said yes. I took vehicle in and they had no clue how to do it and had a mechanic who had no idea of what he was doing trying to do it. I saw them hitting car with mini sledge hammer trying to remove arm. Voiced my opinion about the matter! They refused to give me phone number to corporate, refused to release my vehicle and the manager got physical with me and I was forced to defend myself (me 5'5" 145 him 5'10" 225). He had a broken nose and I was charged with aggravated battery. I forgot to mention he had history of physical altercation with another customer that was withheld and all the video footage from security cameras was destroyed (multi camera system). Take it to another reputable foreign car specialist. That incomplete upper control arm job at Sears has cost me over $20,000 in legal fees and I am still battling this matter trying to clear my name as the prosecution spun a story of me conspiring to walk in off the street demand to get my car fixed and being upset beat manager up which was total BS.
Old 11-30-2009, 08:25 AM
mystrodo's Avatar
Well you learn something everyday..brake fluid is not that expensive and every shop I know uses a simple power flusher which replaces old with new so unless your dealing with morons..which could be the case, I don't see this process as being overly *euro complicated. As far as using expensive fluids. Audi shops buy fluids in bulk in my region the NW and they use BP fluids and oils---Castrol IOW's.
A6Gary has the right suggestion especially for am_ver whose a DIYer..but you do need to get the car off the ground and sometimes that's a PITA.
Old 11-30-2009, 09:17 AM
The G Man's Avatar
Do you change your oil at Jiffy Lube? If so , then Sears is ok
Old 11-30-2009, 03:13 PM
KevinGary's Avatar
Very funny.
Old 11-30-2009, 08:45 PM
am_ver's Avatar
wow... hardly something you'd expect from a big brand name like Sears. Which city was this at?
Quick Reply: Brake Fluid flush at Sears Autoshop?
