Brake lights
Yup you would have to replace the entire tail light assembly to change the brake lights. Tail, back up, and rear fogs are easy bulb replacements.
I'll try to get some pics for you later today.
Check this thread... it has how to remove the housing somewhere in it.
https://www.audiworld.com/forums/sho...ar+brake+light
Thanks kemer1 and spence341.I checked the thread didn't find anything helpful.Btw I removed the screw but couldn't take out the light housing for some reason,maybe I'm doing something wrong?
That screw is the only mechanical fastener that holds it in. On the side of the tail...that connects with the qtrpanel there are 2 clips. Just stick a trim removal tool, or a flathead with a towel wrapped around the blade between the tail, and the panel and gently pry it. It will pop right out. Simple.
jjcuff1
A6 (C7 Platform) Discussion
09-08-2015 12:02 AM
DannyG123US
09-07-2015 05:53 PM
stormchaser1967
09-02-2015 09:26 AM
