A/C stopped working- Help
Today in central Florida, the temp got up to 86 deg F. So, it was the first day that I have had the A/C on since October. I pushed the econ button and to turn on the A/C and no cold air. Also, there is no increased power draw from the motor that usually happens when the a/c condensor pulley starts to give resistance. At at stop light, I tried the same thing and no change in rpms. Therefore, I'm under the impression that there is either something wrong with the a/c belt, condensor, or electrical signal from the 'econ' button to tell the condensor to start working.
Any thought?
Any help would be greatly appriciated.
Thanks.
-2005 Audi A6 3.2Q
Any thought?
Thanks.
-2005 Audi A6 3.2Q
Any thought?
Thanks.
-2005 Audi A6 3.2Q
Any thought?
Thanks.
-2005 Audi A6 3.2Q
First thing I would do is scan the 08 HVAC unit for any DTCs. It could simply be the AC pressure switch. Of course, if the R-134 refrigerant is low, you will also get a DTC from the pressure switch.
Thanks to everybody for your help.
