C6 RS6 Steering wheel
#11
So if is not plug and play, what changes need to be made. I have the wheel, but not the airbag yet. I have seen on S/A4's there is a pin change required for the Multi function features to work. Was it the same on this?
#14
By the way, the C6 RS6 steering wheel is different than the TT steering wheel. The RS6 has the air leather (perforated) and is shaped noticeably more aggressively.
#15
You can get air leather in the TT style too, but I prefer the smooth leather for comfort which is why I opted for this variant. Also yes the RS6 wheel has more contouring, but I got this setup for half the price
#17
Thanks for that. I did mine over the weekend, and I took a differnt approach. I swapped the S6 airbag harness onto the R8 airbag. All I had to do was change the spade crimps for the horn and grounds(there are 2 grounds on the R8 bag, 1 on the s6 so you need to make a "y" connector) Strange that for me, no re-wiring was required withing the connector. Simply swapped harnesses and plugged in the connector and everything worked fined. All MF buttons, lights and paddles etc. All said and done, once I had all the tools ( like a T55 torx bit to get the wheel nut off that I had to go and buy) Probably 20 mins of work. Super simple mod, and looks killer. Now I need some RS6 Pedals.
#18
Hey guys I just purchased my first audi 2 weeks ago an 06 A6, my question is what would be the easiest way for me to do this mod as I have no experience with things of this nature but really want this mod, I do not have paddle shifters on my vehicle is that an issue?. Ideally I would like to just buy exactly what I need and pay someone to do it for me, can you guys tell me exactly where to buy the steering wheel I need and explain the issue with the airbags? Thanks.
#19
For your situation, Alex will probably recommend the TTRS steering wheel, since it doesn't have the paddle shifters. See here:
http://www.audizine.com/forum/showthread.php?t=319491
The RS6 steering wheel pictured is actually mine, just after he finished the badge swap before sending out to me.
I'll follow this post with another with specific instructions on how to perform the swap. As posted previously, easy as pie.
#20
Following is what I did/ used to swap the OEM S6 steering wheel to the Euro RS6 steering wheel. The procedure is as outlined in the Bentley service manual.
1. With the car running, turn the steering wheel 90 degrees to access one of the caps/covers and bolts for the airbag. Pop the cover off, and loosen the first bolt using a T30 torx driver (underneath the column is easiest). Turn the steering wheel 270 degrees, and repeat for the second airbag bolt.
2. Straighten out steering wheel so it is perfectly straight.
3. Turn off engine, but leave the ignition on with the key in the ignition.
4. Access the battery in the trunk. (I engaged the trunk lid latch with a screwdriver to prevent it from latching accidentally if it closes.) Remove the cover over the battery with a 13mm wrench. Disconnect the negative terminal on the battery using a 10mm wrench. ** IGNITION MUST BE ON WHEN DISCONNECTING** (I don't know why, but this is explicitedly stated in the Bentley manual for airbag disconnection.)
5. Ground yourself by touching the inside door handle before removing the airbag.
6. Pull out airbag slightly, and disconnect both the airbag connector and the multifunction switch connector. (Squeeze down on the top of the airbag connector to release and pull it out.) Remove the airbag, and set aside face up.
7. Remove steering wheel bolt using a 12mm 12-point/triple square bit (T55 torx supposedly works also, but I used the correct triple square bit).
8. Mark the center of the spindle with a fine felt tip permanent marker. Double check that steering wheel is centered.
9. Remove the old steering wheel (no steering wheel puller required !!!).
10. Replace with the new steering wheel, centering it as best you can - note that the mark you made on the spindle may not line up exactly with the mark on the new steering wheel. Just make sure that the wheel is perfectly straight.
11. Replace the steering wheel bolt.
12. Connect airbag and multifunction connectors, seating the multifunction wire and connector into the recess in the steering wheel base.
13. Place airbag into the steering wheel.
14. Jack up the front of the car so that you can turn the steering wheel easily to 90 and 270 degrees.
15. Screw in the airbag bolts, but do not snug them down yet.
16. Push on the airbag 3 times minimum to seat it properly, then tighten the airbag bolts.
17. Replace the caps/covers over the airbag screws.
18. Lower front of car.
19. Reconnect the battery ** WITH THE IGNITION ON**
20. Resyncronize all keys by inserting them into the ignition, and starting the car for each key.
21. Lower and raise all windows with the auto down and auto up function.
22. Reset the time, date, and trip computer as they get zeroed out when the battery is disconnected.
23. ** Note: ESP light will go out after driving for a bit.
24. Test drive and verify all functions on the steering wheel.
25. Enjoy.
25. Enjoy.
