Cleaning Roof (interior)
What do you use to clean the upholstery on the roof? I have a small (light brown) stain I want to try and get out. My interior is platinum.
http://www.woolite.us/faq.php
Keep us posted.
I think you mean Headliner and I hope it's not blood splatter (I watched Pulp Fiction again lastnight
I'm not sure what the Headliner material is so use something very mild until your sure..maybe Woolite Complete, it will clean sensitive materials such as silk. Check the FAQ:
Keep us posted.
Keep us posted.
No its just dirt. My dumbazz used a can of shampoo (with the brush attached) to get a small stain out after I had used it on my floor mats and it made it worse. Anyway, will give it a go.
Headliners are very delicate, they can be ruined fairly easily! luckily the Audi material is a bit more robust then most but still use care!!! Do not soak the liner!! if the foam gets wet it can detach very easily from the roof or from the cloth, generally I use Simple green with just a light misting spray on the liner and then wipe with a towel. you can wet the towel if this helps, better to do it in more then one day then soak the liner
mcpath
03-13-2004 12:24 PM
orbital576
05-06-2001 07:49 PM
TCMiller
08-04-2000 07:13 PM
