Climate Control temperature/blower Issue?
it's getting cold so I was playing around with the heat, I've noticed that the higher I turn the temperature the less pressure comes from the front vents. So when I have it on low it's blows the AC cold and hard through the front vents but when I turn the **** to Hi you can barely feel the heat coming out. It seems as if the blower power shifts because I feel the heat blowing very hard from the "front Windshield" vent. Is this normal?
Its because there are multiple temp sensors in the car so if the feet ar hot it will try to cool them down and if the main vent sensor is cold it will equal that out as well..
I seem to get very little control on the heat from ~70 to high. It always seems too hot. Anyone else
Audeye A6
10
03-27-2008 10:40 AM
