Control arm question
The hits keep on coming, I brought my 05 in for tires and a state inspection. Shop called and told me that 4 control arm bushings are torn and need to be replaced. When all is done it will be about $1,000 including labor.
If I'm going to spend that kind of money should I pay to get the entire control arm replaced? What would that most likely cost?
An indy that I trust. I miss understood what he was saying I thought they would repack the bushings but they are going to replace the whole control arm instead.
Does 1k seem resonable? I have an exended warrany so I think this is covered.
you can replace all front four upper control arms in less than 2 hours. Repair manual tells you to remove front struts but you can do it without removing front struts. Hope the Indy shop knows how to set the control arm heigh (very important)
I am not sure what the part is exactly, but lower control arms go for $300, upper links for $200, $1,000 would seem reasonable for both if that is the case.
If it is covered under an extended warranty, I would have an Audi shop do it. I use the dealer for all warranty work and an independent that specializes in Audi/VW for everything else.
The control arm kit, including inner and outer Tie Rods costs $250 from FCP Groton. I just ordered them and installed them. Very happy. Otherwise, you can find kits for under $600 at many places online. The labor is not too difficult. But since you're having it done under warranty, I would do the whole set up, including inner and outer Tie Rods. Unless, you want to do this again in a couple of years.
There is a lot of discussion on which control arms to get (Meyle, Febi, etc). If you do it through the dealer, they will obviously use factory. But if you go independent, you might want to research a little. This forum is a good place to start along with the other Audi forums.
Good luck!
My local Audi USA dealer told me today that the bushings were worn out on the front upper control arms of my 2005/6 Audi A6. Total repair cost of $1,700 (parts & labor) including alignment.
FCP Groton's web site shows upper control arms costing $55.
Although I am CPO, dealer says this is normal wear and not covered under Audi CPO.
There appears to be a lot of daylight between a $55 part and a $1,700 total bill. Advice would be welcome.
PS. The reason you get that price is through a "group buy" from Audizine. Just tell them you want the group buy if you decide to go that route.
Good luck!
Good luck!
