Disabling TPMS
#11
#12
#14
#19
OK, I found this response in VAG forum regarding C6 A6. Does this make sense to anyone with a Vag? I'd like to give the correct instructions to the service tech.
On C6 A6 it should be in Long Coding in the CAN Gateway, Byte 03 Bit 0
Long Coding Helper included with the version 512 of VAG-COM will make this MUCH easier than trying to twiddle the correct but "by hand".
Let us know if it works.
-Uwe-
http://www.ross-tech.com/vag-com/tou...en.html#helper
-Uwe-
#20
I think I may have found the solution..Went into MMI "CAR" then pressed "Change Wheels". Now the TPMS error no longer lights up! Not sure if this is a permanent fix or if it will come back on.
