Last edit by: IB Advertising
- Audi A6 C6 How to Replace Fuel Filter<br>Step by step instructions for do-it-yourself repairs.
DIY 55k Service 2005 C6
#21
To set the service Reminder Indicator go to "SRI Reset" tab on the main screen. It will have the following with your values stored:
Mileage since service milesx100
Time since service days
Min mileage to service milesx100 50
max mileage to service milesx100 100
Max time to service Days 365
Oil Quality
Soot Qty kmx100 0
Thermal Load kmx100
Min time to service Days 365
Click reset and your service light will shut off.
Oil Quality
Soot Qty kmx100 0
Thermal Load kmx100
#26
Don't quote me on this but I belive that the oil change (more oil obviously), spark plugs (not sure what the gap is though), air filter, cabin filters and lubing are the same. Not sure about the fuel filter installation as the part number is different for the 4.2L.
All the part numbers are the same except:
Oil filter
Fuel filter
Oil filter
Fuel filter
#27
Oil filter
Fuel filter
Oil filter
Fuel filter
#28
Thank you racer - You are the best!!
Attaching TSB for oil filter change
"When changing the oil filter and installing the new filter seal(s) in the oil filter housing, special attention is required.
Note: Be aware that this seal can be installed inside-out, which must be avoided to prevent oil leaks."
I did the fuel filter replacement as well yeesterday. I put the car on ramps which worked great for me. The only hard part was taking those pipes out - the blue one came off easy. The black one on the same side had to be pressed on both the sides and removing this was harder than the blue one. The pipe at the other end had some kind of clippy which I was not able to see initially.
#29
