Last edit by: IB Advertising
- Audi Q5 How to Replace Brake Fluid<br>Step by step instructions for do-it-yourself repairs.
DIY Brake Fluid Flush
#22
Just did this today following the DIY here. Everything was smooth. Only thing I can add here is that I used an dental syringe used to flush back teeth after oral surgery to suck the old fluid out of the reservoir … thanks to the person that mentioned the yellow cap. There are 2 small holes under the yellow cap, the dental syringe fit perfectly and pulled out the correct amount of fluid (not allowing the reservoir to run dry).
I could not figure out how to pull out the screen and since everything is plastic didn't want to damage it … luckily saw the comment about the yellow cap.
#24
Yes. Used the same procedure on my 2006 A6 Avant and my 2014 Q5. However, you can reach the bleeder valve on the front Q5 calipers through the wheel w/o removing the wheel - makes it easy to bleed the system at least on the fronts.
#29
Thanks, any special tool needed like the Vagcom?
