A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Old 07-25-2016, 09:21 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi Q5 or Q7 Brake Guides
Print Wikipost
DIY Brake Fluid Flush
Old 09-16-2016, 11:52 AM
  #31
2014Q5's Avatar
Originally Posted by A6Gary
Nope, just a pressure bleeder, a bottle/tube to collect the old fluid, and a couple of wrenches.
Great, thank you very much!
Old 11-19-2016, 12:16 PM
  #32
PopsTheSailor's Avatar
I have a 2003 TT. The brake booster went out so I had to replace it. That means I have both issues, which are: 1) ABS is dry (I removed it completely to get the booster out) and 2) Air in the lines (since I had the master cylinder off). I don't have a VCDS/Vag-Com yet.
So my questions are:
1. Can I get started on bleeding the lines while I get the VCDS?
2. Since I have a dry ABS and air in the lines, do I still pretty much follow the OP's directions? I bought a vacuum bleed kit and will use that method unless someone tells me one of the other methods are better because of my situation.
3. Do I need the actual VCDS software / cable or will one of the hand held devices you can find on places like Amazon work for the ABS pump refill?
Any other help, suggestions, comments on my situation would be very much appreciated.
Old 04-06-2017, 10:26 AM
  #33
2014Q5's Avatar
Didn't get a chance to do it until last week. It wasn't that hard as I thought it would be. Again, thank you very much for the DIY. The old brake fluid ate up my plastic turkey baster really bad though, it looks like it's shattered. Should have gotten the glass or stainless.
Old 11-02-2023, 02:30 PM
  #34
hcrossing's Avatar
Default Do I need to open the nipples?
For this procedure, bleeding the ABS pump, do you need to have the front, or rear, bleeding nipples open? Or do you just run this through vcds without hooking anything up to the lines.
Procedure for Bleeding the ABS Brake Pump on VW Passat and Audi A4/S4, A6/S6, and A8/S8:[Select]
[03 - ABS Brakes]
[Basic Settings - 04]
Group 002
[Go!]This will trigger the ABS pump to turn on for about 10 seconds. You should hear the fairly loud pump clicking during this time.Click the [Done, Go Back] button and you're all set[/Qfollow.
Old 11-03-2023, 04:54 PM
  #35
Sallad's Avatar
Yes open the nipples so the old fluid can escape the system, but make sure to keep topping up the revivour so you get too low on fluid and suck in air. Do each nipple separately, not all four at once.
aca
Brakes Discussion
05-28-2006 04:46 PM
slightly disgruntled
05-01-2006 05:40 PM
SteveK-O (stock!)
04-25-2005 11:57 AM
Krisko
Florida Discussion
03-30-2004 04:33 PM
BSCA4
08-09-2002 05:41 AM
Quick Reply: DIY Brake Fluid Flush
