Last edit by: IB Advertising
- Audi A6 C6 How to Replace Brake Pads Calipers Rotors<br>Step by step instructions for do-it-yourself repairs.
DIY Rear Brake Pad Replacement
#52
It is possible to replace the rear pads without any software. It took me a lot of figuring out, but we figured out how to get the caliper piston in without damaging it. Basically, we had to unbolt the electronic motor from the caliper (2 torx screws). The motor assembly pulls straight off with a little persuasion to reveal a spline drive input on the back of the caliper. We used a torx bit (allen would probably work too) to screw in the e-brake piston (the e brake motor operates a piston on a screw,internal to the actual caliper piston). Once the screw is all the way in, the e-brake piston is backed off, and the caliper piston can be pushed in easily.
When you just mechanically retract the piston the ECU retains the old positioning information with the thinner worn out pads. This can cause problems not only with braking but also affect the ABS system.
#53
Find somebody with VAG-COM and do the retraction/calibration procedure. The procedure not only retract the piston, it also calibrates the position of the piston after new pads are installed by cycling the piston back and forth few times.
When you just mechanically retract the piston the ECU loses this information and can not determine where exactly the piston is. This can cause problems not only with braking but also affect the ABS system.
05whtaudia6
10
03-20-2008 09:24 PM
