DIY Springs: Info and tips please (yes, I searched)
My bro in law (who also happens to be a Honda mechanic) are going to be installing springs at his shop either tomorrow or a little later.
Fronts seems easy enough, can you please provide some insight as to anything special we can expect from the rear springs? I know it get a little tricky.
I searched and didn't find much on the forum.
Write ups, tips, pictures, explanations, links, it's all appreciated.
Thanks
Thanks
here is Passat DIY.. for the front..
http://home.comcast.net/~hhong4/kmacinstall.htm
there was a post on the A6 front springs not too long ago.. couple of months at most. Haven't seen anything for the rears.
Front is cake, just clock the bushings up higher since the a arms will be sitting at a higher angle vs stock. The rear is a nightmare if you don't have the right type spring compressor. You need one that has to plates that go onto the springs and are tightened together by a bolt in the middle of the spring/tool.
hey i am looking at this tool..
do u think its designed to do the job as u described?
![](http://c1552172.r72.cf0.rackcdn.com/190361_x600.jpg)
I used these compressors, but I used them after taking of whole spring/shock assembly of the car. And even then it is hard to put these hooks on and off the spring coils. The Audi compressor looks much more convenient.
Like this style:
http://www.ebay.com/itm/Performance-...#ht_1512wt_782
cabriolet rear springs (8G0 511 115a) are cabriolet specific springs fronts are same as B4 except 93
wisconsin_quat
15
09-05-2003 05:31 AM
S4er
05-09-2001 03:59 AM
