Last edit by: IB Advertising
- Audi A6 C6 How to Replace Upper Control Arms Bushings<br>Step by step instructions for do-it-yourself repairs.
DIY upper control arms?
I did this once on my Passat. I'm not sure how well the DIY instructions would translate to our A6's. The info was on passatworld.com. Sorry I can't be of more help.
here is DIY for passat. I just took it to the shop since the car requires an alignment after these are installed.Factor in the cost of the alignment and the package doesn't seem bad.
http://home.comcast.net/~hhong4/kmacinstall.htm
Luckily I have the Fidelity extended warranty. I just had all 4 of my uppers replaced at the dealer. Cost was $1,400. But I got away with paying $100 deductible and $149 for alignment.
Turborusty
Turborusty
Why did you need to get the uppers replaced - uneven tire wear? Usually, the lower is first one to get shot.
I had my front upper replaced due to a failed bushing. The problem manifested itself in a clunking sound over washboard type bumps. Covered under warranty, but it took some coaxing.
I have the same issue. Failed bushing. I need to replace the 4 upper control arms. Any suggestions on where to buy them? Audipartsnationwide is $179 each. Whoa.
My rear struts could use replacing too.
I guess it does have 106k miles.
The main reason I started this thread was to if any one knew the procedure for getting the upper control arms out. also if there I need to (adjustments etc..) when putting them back in.
PLEASE SOMEONE HELP!!!!!
This should help, since the A6 C5 and the A6 C6 front suspensions are very similar:
http://www.youtube.com/watch?v=jrYAAtlsjnY
