Does Check Engine Light Auto Reset after a while???
I was performing the 3M Tune Up In a Bottle procedure and in the process lodged the spray hose in the throttle blade which in tern turned on the Check Engine light. The vehicle does not give me any codes or faults thru MMI so my question is if this condition no longer exists will the check engine light go off after so many power cycles or will I have to spend money on VAGCOM??
Thank you
Thank you
Thank you
Thank you
removing the battery cables does not work!!! I dont know why so many people on this forum seem to think so. its a Keep alive memory that will not just go away. You can remove the ecu from the car with no power to it for months, put it back in and still see the same codes remain. Stop wasting time and loosing the default radio and window auto down memory...
Most of the codes have a reset counter which is decremented every start-stop cycle. A common number for the rest is 40 cycles so it can take some time for the light to go off. You can reset it with a VAG-COM or OBDII tester remove the battery cable as suggested by tenspeed. The problem with removing the battery cable is that you may loose some other settings.
