Doesnt start
Doesnt start
Hi.
i have Audi C6 A6 2006 2.4 petrol car. Bassicly car doesn't start. When I turn key starter is working but engine doesn't start. Plug to computer when it happen some time ago and it showed that from battery is coming 0.6 volts. It's ussualy happens randomly .It can be ok for weeks and than just start again. Changed crankshaft position sensor. No difference. Maybe someone had similar problem?
Hi.
i have Audi S6 2006 2.4 petrol. Bassicly car doesn't start. When I turn key starter is working but engine doesn't start. Plug to computer when it happen some time ago and it showed that from battery is coming 0.6 volts. It's ussualy happens randomly .It can be ok for weeks and than just start again. Changed crankshaft position sensor. No difference. Maybe someone had similar problem?
Have you bench tested your battery to ensure it is good? If you're not sure as to when the battery was last changed...I'd swap that out first and then proceed to other troubleshooting.
Will try to test it first. It just doesn't make sense as it is working ok can start 50 more times and than starts again. But thanks will deffinetly try to test it first
