Door Module/Wiring Errors
The only physical issue I see is that the mirror will not fold in or out, right door is fine, 100%. Seems like a lot of errors....
Feedback is appreciated.
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 E HW: 4G8 959 793 A
Component: TSG FA H05 0212
Revision: -------- Serial number: --------------
Coding: 011F17205E00628002000012
Shop #: WSC 02391 785 00200
VCID: 428B7DDFDD5B975FCF-8016
6 Faults Found:
01482 - Motors for Central Locking
006 - Short to Plus
Freeze Frame:
Fault Status: 01100110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Mileage: 220660 km
Time Indication: 0
Date: 2019.08.15
Time: 12:09:53
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Mileage: 220660 km
Time Indication: 0
Date: 2019.08.15
Time: 12:09:53
02116 - Mirror Adjusting Motor
006 - Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Mileage: 220660 km
Time Indication: 0
Date: 2019.08.15
Time: 12:09:53
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Mileage: 220660 km
Time Indication: 0
Date: 2019.08.15
Time: 12:09:53
02117 - Motor for Mirror Folding
006 - Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Time Indication: 0
6 Faults Found:
006 - Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Mileage: 220660 km
Time Indication: 0
Date: 2019.08.15
Time: 12:09:53
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Mileage: 220660 km
Time Indication: 0
Date: 2019.08.15
Time: 12:09:53
006 - Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Mileage: 220660 km
Time Indication: 0
Date: 2019.08.15
Time: 12:09:53
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Mileage: 220660 km
Time Indication: 0
Date: 2019.08.15
Time: 12:09:53
006 - Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Time Indication: 0
Judging by the faults, the most basic thing to assume would be, the wires in the folding mirror due to age have broken, and or also seams like the door latch lock might be experience the same thing. Regardless of the faults, first thing i would do is peal back the rubber accordion grommet in the FL door jam where the wires flex and inspect the wires for breakage and or the wire insulation cracking and having exposed wires touch each other. Verify the Fl door lock. Then also open the door all the way and see if all the functions work as well.
Thanks, that is next on the list. I went back over and while the door locks work, the proximity sensors do not and the doors will not unlock without the key fob being pressed. After repairing a broken wire for the outlets and the MMI, this sounds reasonable to me.
Appreciate the feedback!
jeffkruse
Q7 MK 1 Discussion
11-16-2018 05:36 PM
Hassan2869
01-23-2017 02:28 PM
Hassan2869
A6 (C7 Platform) Discussion
09-08-2012 11:58 AM
