door speaker grill?
How do we remove that grill on the bottom of our door..
do i have to remove the door panel>?
if so.. How!>?
thnx
kicking my self in the a_s here
if so.. How!>?
thnx
I never seem to get an answer with any of my questions..
Am I asking rhetorical questions here.. or have I been boycotted?
I need help.. Anyone?
This what I got from a quick search.
1. I started with the window down.
2. Remove 2 screws that hold door panel in, one in front jamb, one in rear.
3. Pop out the power window switch, there is a small hole in the underside of the door handle that you can put a small screwdriver or allen wrench in and pry from the front of the switch toward the rear of the car and pull up.
4. Disconnect window switch.
5. Pull door panel up and off. not too tough.
6. Disconnect 3 wires near front of panel, 2 for speakers, third for ?? didn't trace them out.
7. Put the door panel in a safe place.
grill has melted pins at backside of panel..
so the panel must off..
Panel dissasembly:
#Remove tweeter grill (use small screwdriver at top of grill) there is one screw under the grill...
#Remove "trimpanel" the panel at side of tweeter (i have my memory seat buttons coming out of that panel) put fingers under panel and pull out..start from the tweeter side and out..(i broke off some plastic guides though..but they can be glued back..)
under that panel is 2 screws
#Remove screw under armrest
#Redmove screw at middle bottom of doorpanel
#Remove panel by unciping it starting at bottom
(my was real hard to unclip...seems some clips had been glued from factory
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
Good luck!/H
A6turbo530
09-24-2006 08:30 AM
absolutcq20v
13
02-24-2005 03:37 AM
AizazBlack//S4
08-25-2002 09:04 PM
