Dr. Tranny for torque converter shuddering?
I just got a 2007 A6 with 75,000 but I'm noticing 250-500 RPM jumps iwhen I'm right around 30 MPH. I'm guessing that could potentially be a torque converter issue down the road. Upon asking my audi guy he suggested trying Dr. Shudder Fixx or Dr. Tranny (drtranny.com). Has anyone used these in the past and did they work? Also, this comes in a tube to be added -- where do i access the transmission fluid container? Thanks in advance!
Hi, would you ever consider servicing the transmission? It's not a bad strategy if you intend to keep the car a while.
Get new transmission fluid in the tranny and change the filter first, before you consider adding any "snake oil" or other magic elixirs which will solve the issue.
Read the following guide and it'll help you understand how the service your tranny.
https://www.audiworld.com/forums/a6-...fluid-2816950/
Here's a video of the process...BTW, I don't recommend using an electric drill to torque down bolts.
I have that same issue, my car jumps when am about, 25-30mph, and the rpm jumps from 200 to 180 you guys recommend me to get it service at a audi dealer or transmission shop?
I had the TC replaced when I had the timing chain guides and tensioners replaced. The total bill was about $10k. But you should try changing the fluids first.
zachf88
RS4 (B7 Platform) Discussion
03-18-2009 06:58 AM
kalpesh
08-03-2007 04:20 AM
BigThistle
10-08-2003 07:47 AM
