dropping rear subframe to get to springs -- anyone with a bentlays manual
i need to adjust the ride height of my rear coilovers -- and because the way the rear is setup i can't get a spring compressor into the space to compress the spring and increase the height. So i need to undue a few bolts and drop the arms on which the spring sits.
Someone posted a vid of this being done on an 89 Benz -- same theory. can someone with a Bentley's manual take a couple screenshots of which bolts i need to undue to drop the arms which hold the sping in place? and also what constitutes dropping the subframe.
The fronts i can just raise with the tool provided, but because in the rear the sping is seperate from the strut when i turn the adjustment "****" the whole thing just rotates
... thanks for the help.
Thanks.
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
Thanks.
Let me know which section you need from this menu item for rear suspension.
Thanks.
Thanks.
i think the first one... removal and installation? from looking around in there and what installer told me a couple years ago you have to drop subframe to install springs... thus it should be in the first one.
BVRN_RKT_94_90
04-22-2004 11:12 AM
ND4SPD
27
07-24-2002 02:33 PM
sTTanford
02-14-2002 07:45 AM
