ECS 100 (V-Checker Pro) Not Idiot Proof, help!!!
I just changed my oil and was trying to reset the service warning using a ECS 100 (V-Checker Pro). I know, I know, "I should have gotten RossTech" but I got the V-Checker Pro now. I followed the manual instructions which are not that great to begin with and cannot reset the service warning. There are times that I get a communication error and other times that it seems to be working but nothing happens after I hit the command. The manual instructs to connect the cable with the ignition off and perform the commands with the ignition off. Does anyone knows how to work this thing and show me how to reset the service warning? Thanks in advance.
I'm not an expert on this; I used the ECS100 successfully to open and close the rear electronic parking brake, but have not tried to use it for resetting the service indicator.
Anyway, you definitely want to connect the device with the ignition in the off position, but I believe that the ignition has to be "on" to actually communicate with the device. The one tip I found out about when using the device for the brakes, was that to actually initiate a command (vs. just selecting an option), I had to hold down the left button for a second or so, instead of just a quick press.
Good luck. I'd be interested to know if you get it to work.
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
I guess being a good guesser helps.
I had the thing connected for less then 2 minutes and reset mine.
Look in the menu for the one marked oil and select it and it will change
to show 3 items oil and two in? somethings. I selected oil and said yes
and it now it doesnt show service when I put the key in to turn the car on.
If I figure out more I'll try and put a step by step for you.
Yep, that's what I get too. Another function that did not work for me is the battery reset [61]. I tried everything and spent all kinds of time trying to rest the battery and nothing. I think I might take on ECS offer to buy it back and buy RossTech.
