Electrical problems.. Tail lights failing!
Hello!
I am really desperate to solve this mistery. Yesterday a rear bulb on my right light died, so I've gone to replace it. It worked okay for an hour and then the other two bulbs failed. An interesting thing is that they eventually come up or blink for a couple of seconds and then die again.
I have now replaced all of the bulbs with new ones ant the problem is still here![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
Here is my VAG-COM log:
VCDS Version: Release 10.6.0
Data version: 20100630
Tuesday,28,December,2010,11:57:56:46862
Chassis Type: 4F0
Scan: 01 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61 62
72 76 77
VIN: WAUZZZ4F6xxxxxxxx Mileage: 142560km/88582miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (BDW) Labels: Redir Fail!
Part No SW: 4F0 910 552 R HW: 4F0 907 552 C
Component: 2.4l V6 MPI 0010
Revision: --H13--- Serial number:
Coding: 0105000318070020
Shop #: WSC 07137 298 67820
VCID: 326018969275778C
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 D HW: 4F0 614 517
Component: ESP8 front H03 0010
Revision: 00000000 Serial number: 00000000000000
Coding: 0004433
Shop #: WSC 07125 298 68012
VCID: 254AF3CAD3BB1034
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0220
Revision: 31050601 Serial number: 10600300031983
Coding: 0000001
Shop #: WSC 07137 298 64085
VCID: E3CE2DD21D0F2E04
Part No: 4F0 910 131
Component: FBSAUDIC6 EZS H43 0070
Part No: 4F0 910 220
Component: FBSAUDIC6 IDG H35 0020
1 Fault Found
01049 - Supply Voltage Term 50
006 - Short to Plus
Freeze Frame:
Fault Status: 01100110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 225
Mileage: 142564 km
Time Indication: 0
Date: 2010.12.28
Time: 11:52:47
Address 07: Control Head Labels: Redir Fail!
Part No SW: 4F0 910 729 P HW: 4F0 035 729 F
Component: MMI Cockpit H90 0120
Revision: C41300FE Serial number: AUZ6Z3D5UD10U1
Coding: 0104102
Shop #: WSC 02327 785 00200
VCID: 366824867E1D6BAC
Part No: 4F0 910 609 B
Component: Bedienteil MMIC6H07 0010
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 H
Component: KLIMABETAETIGUNGH11 0100
Revision: 00000022 Serial number: 00000000026224
Coding: 0000006
VCID: DBBE1532257F16C4
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 B HW: 4F0 907 279 B
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0000111
Shop #: WSC 02335 785 00200
VCID: 2854FAFEA4A90D5C
Part No: 4F1 910 113
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0040
Coding: 00141886
Shop #: WSC 02335
1 Fault Found
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01111110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 225
Mileage: 138596 km
Time Indication: 0
Date: 2010.10.25
Time: 13:47:00
Address 0E: Media Player 1 Labels: Redir Fail!
Coding: 0104102
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 G HW: 4F0 959 655
Component: 20 AIRBAG AUDI8RH24 0110
Revision: 07H24000 Serial number: 00358D05K4KZ
Coding: 0012848
VCID: 2B5E05F2B55F2644
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H06 0130
Revision: 00H06000 Serial number: 90025041570029
Coding: 0002011
VCID: E6C834C6EE3D5B2C
Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 900 K
Component: KOMBIINSTR. M73 H07 0630
Revision: 00700000 Serial number: 49B15F064
Coding: 0260143
VCID: 1E38DC26F6EDC3EC
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 080080453001E6
Coding: ECEE53C41B1104
Shop #: WSC 02325 785 00200
VCID: 2756F9C2A9B70224
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 C HW: 4F0 959 793 C
Component: TSG FA H10 0020
Revision: 00000000 Serial number: ‰
Coding: 0000522
VCID: 2A5000F6BAA53F4C
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01000242930000
Coding: 0131313
VCID: 2C5C06EEB051217C
Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Part No: 4F0 910 177
Component: Innenraumueberw.H01 0010
4 Faults Found
02199 - Bulb for Tail Light 2; Right (M50)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 36
Reset counter: 225
Mileage: 142521 km
Time Indication: 0
Date: 2010.12.27
Time: 07:47:11
02735 - Bulb for Tail Light 3; Right
Freeze Frame:
Fault Priority: 3
Fault Frequency: 46
Reset counter: 225
Mileage: 142521 km
Time Indication: 0
Date: 2010.12.27
Time: 07:47:12
01505 - Bulb for Blinkers; Rear Right (M8)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 225
Mileage: 142536 km
Time Indication: 0
Date: 2010.12.27
Time: 12:34:59
01519 - Bulb for Back-Up Lights; Right (M17)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 225
Mileage: 142540 km
Time Indication: 0
Date: 2010.12.27
Time: 19:55:17
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 B HW: 4F0 035 223
Component: Amp.-ASK H09 0270
Revision: 12S00001 Serial number: 00406040011878
Coding: 0000004
VCID: 1D3ADB2AFBEBD8F4
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H07 0040
Revision: Serial number: 00000000013639
Coding: 0001104
Shop #: WSC 02323 785 00200
VCID: DEB81C26366D03EC
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 792 C HW: 4F0 959 792 C
Component: TSG BF H10 0020
Revision: 00000000 Serial number: 1€
Coding: 0000522
VCID: 2952FFFABFA33454
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0002011
VCID: DDBA1B2A3B6B18F4
Address 56: Radio Labels: Redir Fail!
Coding: 0104102
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0490
Revision: 00000000 Serial number: 00000000057243
VCID: 234EEDD2DD8FEE04
Part No: 4F0 915 105 B
Component: von MLA 0406020200
Coding: 34463039313531303542204D4C4130343036303230323030
Shop #: WSC 07137 298 06412
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
Component: TSG HL H09 0010
Coding: 0000002
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
Component: TSG HR H09 0010
Coding: 0000002
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 B HW: 4F0 919 283 B
Component: Parkhilfe 4-Kan H09 0030
Revision: 00H09000 Serial number: 11720529708307
Coding: 0000006
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 C HW: 4E0 862 335
Component: Handyvorb2 H09 0120
Revision: 00000000 Serial number: 00000007510348
Coding: 0020920
VCID: 2240E8D6C295E70C
End ---------------------------------------------------------------------
Thank you for any help!
Chassis Type: 4F0
72 76 77
Coding: 0004433
Coding: 0000001
1 Fault Found
006 - Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 225
Mileage: 142564 km
Time Indication: 0
Date: 2010.12.28
Time: 11:52:47
Coding: 0104102
Coding: 0000006
Coding: 0000111
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
1 Fault Found
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 225
Mileage: 138596 km
Time Indication: 0
Date: 2010.10.25
Time: 13:47:00
Coding: 0104102
Coding: 0012848
Coding: 0002011
Coding: 0260143
Coding: 0000522
Coding: 0131313
4 Faults Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 36
Reset counter: 225
Mileage: 142521 km
Time Indication: 0
Date: 2010.12.27
Time: 07:47:11
Freeze Frame:
Fault Priority: 3
Fault Frequency: 46
Reset counter: 225
Mileage: 142521 km
Time Indication: 0
Date: 2010.12.27
Time: 07:47:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 225
Mileage: 142536 km
Time Indication: 0
Date: 2010.12.27
Time: 12:34:59
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 225
Mileage: 142540 km
Time Indication: 0
Date: 2010.12.27
Time: 19:55:17
Coding: 0000004
Coding: 0001104
Coding: 0000522
Revision: C63C0030
Coding: 0002011
Coding: 0104102
Coding: 0000002
Coding: 0000002
Coding: 0000006
Coding: 0020920
Have you tried using bulb from Audi dealer? it seem Audi's are very sensitive to third parties bulbs.
Hello!
Chassis Type: 4F0
72 76 77
Coding: 0004433
Coding: 0000001
1 Fault Found
006 - Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 225
Mileage: 142564 km
Time Indication: 0
Date: 2010.12.28
Time: 11:52:47
Coding: 0104102
Coding: 0000006
Coding: 0000111
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
1 Fault Found
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 225
Mileage: 138596 km
Time Indication: 0
Date: 2010.10.25
Time: 13:47:00
Coding: 0104102
Coding: 0012848
Coding: 0002011
Coding: 0260143
Coding: 0000522
Coding: 0131313
4 Faults Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 36
Reset counter: 225
Mileage: 142521 km
Time Indication: 0
Date: 2010.12.27
Time: 07:47:11
Freeze Frame:
Fault Priority: 3
Fault Frequency: 46
Reset counter: 225
Mileage: 142521 km
Time Indication: 0
Date: 2010.12.27
Time: 07:47:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 225
Mileage: 142536 km
Time Indication: 0
Date: 2010.12.27
Time: 12:34:59
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 225
Mileage: 142540 km
Time Indication: 0
Date: 2010.12.27
Time: 19:55:17
Coding: 0000004
Coding: 0001104
Coding: 0000522
Revision: C63C0030
Coding: 0002011
Coding: 0104102
Coding: 0000002
Coding: 0000002
Coding: 0000006
Coding: 0020920
Chassis Type: 4F0
72 76 77
Coding: 0004433
Coding: 0000001
1 Fault Found
006 - Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 225
Mileage: 142564 km
Time Indication: 0
Date: 2010.12.28
Time: 11:52:47
Coding: 0104102
Coding: 0000006
Coding: 0000111
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
1 Fault Found
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 225
Mileage: 138596 km
Time Indication: 0
Date: 2010.10.25
Time: 13:47:00
Coding: 0104102
Coding: 0012848
Coding: 0002011
Coding: 0260143
Coding: 0000522
Coding: 0131313
4 Faults Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 36
Reset counter: 225
Mileage: 142521 km
Time Indication: 0
Date: 2010.12.27
Time: 07:47:11
Freeze Frame:
Fault Priority: 3
Fault Frequency: 46
Reset counter: 225
Mileage: 142521 km
Time Indication: 0
Date: 2010.12.27
Time: 07:47:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 225
Mileage: 142536 km
Time Indication: 0
Date: 2010.12.27
Time: 12:34:59
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 225
Mileage: 142540 km
Time Indication: 0
Date: 2010.12.27
Time: 19:55:17
Coding: 0000004
Coding: 0001104
Coding: 0000522
Revision: C63C0030
Coding: 0002011
Coding: 0104102
Coding: 0000002
Coding: 0000002
Coding: 0000006
Coding: 0020920
It is a common problem. Unfortunately the only known fix is to replace the entire unit, not just the bulbs. Search the forum and you will fin the threads where this was discussed. I replaced the entire unit about 6 months ago and it has been fine ever since.
packge33
07-15-2012 12:17 PM
