Engine warning light on 2010 A6 3.0T
#11
To my point, I did not intend to infer that Audi's are crap. Point of fact, I'm about to spend a lot of money buying one.
However, I stand behind the point that one shouldn't accept CEL's in brand new cars. I don't care if they're the cheapest Hyundai or the most expensive Maybach... accepting CEL's because a car is technologically advanced is silly.
#12
And you're basing your generalization that Japanese cars don't have similar diagnostics as German cars on what exactly? I'd appreciate the data to back that up.
#14
Have them give you a printout of the diagnostics if it repeats..the 3.0 is not really a new design, it's the very reliable 3.2 that was strengthened for the supercharger so what it lost in miniscule size it gained everywhere else performance-wise. Chances are is a very minor issue but it needs to be corrected if it hasn't been. A CEL means something so unless it's fixed how would you know if you had a real issue..ask them that.
#15
#16
Changing the setpoint would just be a bandage, my feeling is that it is set there for a reason. I'm very happy with the car, I guess my question is should I be worried about this.
#17
I wouldn't worry about it yet, it is a small issue that hopefully will be resolved quickly.
I have a 2005, this is the first model year of the C6 and have had a few small issues but never have had a CEL come on.
The Infiniti is a great car but don't give up on the A6.
#18
If the CEL is not blinking and the dealer already know the problem and siad its ok to drive then I would not worry about it. If your dealer is telling you that its is a gasoline vapor evaporating system error code, then it may be a leak in the system or you didnt tighten up the gas cap enough. Make sure you tighten the gas cap until it clicks 3 times. If the CEL keep coming back on, bring it to another dealer while the CEL is still on. Good Luck
#19
I have a 2010 A6 3.0T with 3500 miles. Engine light came on today. Ran the VAG, error code 001109 - P0455 EVAP System: Large leak detected. Possible cause loose gas cap.
I will swing by the dealer tomorrow.
Interesting thought is that I had filled it up the day before, parked it. When I went to start it today, the error light showed up.
While I agree that having error lights come on in a 2 month old car is annoying, having the VAG does provide a high degree of comfort. Invest in one if you dont have one.
#20
