ESP/ABS Light
The ESP/ABS lights are on in my 2005 audi a6 3.2L Q. I've tried replacing the brake light switch but the problem remains.
Do these codes/lights usually mean the ABS Module needs to be repaired or could is simply be the brake pressure sensor?
2 Faults Found:
01435 - Brake Pressure Sensor 1 (G201)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 5
Reset counter: 227
Mileage: 153518 km
Time Indication: 0
Date: 2012.02.21
Time: 19:03:10
Freeze Frame:
Hex Value: 0x3800
Hex Value: 0x4006
Hex Value: 0x001C
Hex Value: 0xB1AD
Hex Value: 0x00FF
00526 - Brake Light Switch-F
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 11
Mileage: 154315 km
Time Indication: 0
Date: 2012.03.04
Time: 13:17:38
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x0004
Hex Value: 0xC1AD
Hex Value: 0x00FF
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 227
Mileage: 153518 km
Time Indication: 0
Date: 2012.02.21
Time: 19:03:10
Freeze Frame:
Hex Value: 0x3800
Hex Value: 0x4006
Hex Value: 0x001C
Hex Value: 0xB1AD
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 11
Mileage: 154315 km
Time Indication: 0
Date: 2012.03.04
Time: 13:17:38
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x0004
Hex Value: 0xC1AD
Hex Value: 0x00FF
Sounds like the ABS module. The same ESP/ABS lights popped up in the B5's when it was proven to be an ABS module. I know that there are places online that can repair your module without too much cost.
Ian Taylor
New Member Welcome Area
11-22-2017 11:39 PM
iNfiNkC
10-31-2009 09:50 PM
Dommi3
10-12-2002 09:31 PM
