ESP/ABS Lights on
Hi, my ESP/ABS lights come on randomly lately. I've read that this is a common issue in audi's...does anyone know how to fix this? I tried replacing the brake light switch for an easy fix but that didn't work?
Thanks in Advance
Here are the codes that came up:
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F1 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0050
Revision: --H15--- Serial number:
Coding: 01050106190F0120
Shop #: WSC 02325 785 00200
VCID: 2A50875EFC97
2 Faults Found:
18975 - Low Pressure Fuel Sensor (G410): Intermittent
P2543 - 009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 79
Reset counter: 40
Mileage: 149556 km
Time Indication: 0
Date: 2012.01.03
Time: 18:46:45
Freeze Frame:
RPM: 672 /min
Mass Air / Rev.: 174.4 mg/str
Temperature: 81.0°C
Idle
Pressure: 4.9 bar
Speed: 0.0 km/h
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 6
Reset counter: 40
Mileage: 153518 km
Time Indication: 0
Date: 2012.02.21
Time: 19:03:10
Freeze Frame:
RPM: 672 /min
Mass Air / Rev.: 130.8 mg/str
Temperature: 70.5°C
Idle
Load: 20.4 %
Speed: 0.0 km/h
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
Shop #: WSC 02327 785 00200
VCID: 2D5A8C42CD79
2 Faults Found:
01435 - Brake Pressure Sensor 1 (G201)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 227
Mileage: 153518 km
Time Indication: 0
Date: 2012.02.21
Time: 19:03:10
Freeze Frame:
Hex Value: 0x3800
Hex Value: 0x4006
Hex Value: 0x001C
Hex Value: 0xB1AD
Hex Value: 0x00FF
00526 - Brake Light Switch-F
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 11
Mileage: 154315 km
Time Indication: 0
Date: 2012.03.04
Time: 13:17:38
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x0004
Hex Value: 0xC1AD
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0160
Revision: 27100401 Serial number: 10600300111724
Coding: 0000011
Shop #: WSC 01405 444 999999
VCID: E3CEAA7A5B3D
Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H43 0070
Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H38 0040
2 Faults Found:
01179 - Incorrect Key Programming
000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 165
Mileage: 118969 km
Time Indication: 0
Date: 2010.12.03
Time: 11:58:12
00166 - Access/Start Authorization Switch (E415)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 31
Reset counter: 51
Mileage: 112580 km
Time Indication: 0
Date: 2010.10.13
Time: 19:28:37
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 B HW: 4E0 035 593
Component: SDAR
Serial number: AUZ4Z7D3007298
Shop #: WSC 00000 000 00000
VCID: 2648736EE88F
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 224
Mileage: 132292 km
Time Indication: 0
Date: 2011.05.18
Time: 09:59:14
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 K HW: 4E0 919 887 C
Component: MNS US H44 0570
Revision: 00000000 Serial number: 378BV057516528
VCID: 356AA4222529
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 49
Reset counter: 0
Mileage: 111403 km
Time Indication: 0
Date: 2010.07.23
Time: 12:11:50
Freeze Frame:
Bin. Bits: 0100
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H15 0100
Revision: 01000015 Serial number: 01002712740000
Coding: 0423997
Shop #: WSC 02335 785 00200
VCID: 2C5C8146F663
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
1 Fault Found:
01503 - Bulb for 3rd Brake Light (M25)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 254
Reset counter: 227
Mileage: 145286 km
Time Indication: 0
Date: 2011.11.08
Time: 08:47:33
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
Shop #: WSC 02334 785 00200
VCID: DDBA9C827D59
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 7
Reset counter: 9
Mileage: 153512 km
Time Indication: 0
Date: 2012.02.21
Time: 19:03:12
Freeze Frame:
Voltage: 13.25 V
Count: 236
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0470
Revision: 00000000 Serial number: 00000000020139
Shop #: WSC 02335 823 00000
VCID: 234E6A7A9BBD
Part No: 4F0 915 105 C
Component: von VA0 2502100427
Coding: 344630393135313035432056413032353032313030343237
Shop #: WSC 00000 384 00290
5 Faults Found:
02277 - Quiescent Current Stage 6
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 3
Mileage: 132289 km
Time Indication: 0
Date: 2011.05.17
Time: 10:11:34
00992 - Consumption Cut-Off Active
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 117360 km
Time Indication: 0
Date: 2010.11.20
Time: 15:35:15
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Mileage: 151652 km
Time Indication: 0
Date: 2012.01.30
Time: 04:43:26
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 132289 km
Time Indication: 0
Date: 2011.05.17
Time: 10:11:14
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 152165 km
Time Indication: 0
Date: 2012.02.06
Time: 16:45:09
End ---------------------------------------------------------------------
Thanks in Advance
VCID: 2A50875EFC97
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 79
Reset counter: 40
Mileage: 149556 km
Time Indication: 0
Date: 2012.01.03
Time: 18:46:45
Freeze Frame:
RPM: 672 /min
Temperature: 81.0°C
Idle
Pressure: 4.9 bar
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 40
Mileage: 153518 km
Time Indication: 0
Date: 2012.02.21
Time: 19:03:10
Freeze Frame:
RPM: 672 /min
Temperature: 70.5°C
Idle
Load: 20.4 %
Speed: 0.0 km/h
Coding: 0020895
VCID: 2D5A8C42CD79
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 227
Mileage: 153518 km
Time Indication: 0
Date: 2012.02.21
Time: 19:03:10
Freeze Frame:
Hex Value: 0x3800
Hex Value: 0x4006
Hex Value: 0x001C
Hex Value: 0xB1AD
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 11
Mileage: 154315 km
Time Indication: 0
Date: 2012.03.04
Time: 13:17:38
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x0004
Hex Value: 0xC1AD
Hex Value: 0x00FF
Coding: 0000011
VCID: E3CEAA7A5B3D
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 165
Mileage: 118969 km
Time Indication: 0
Date: 2010.12.03
Time: 11:58:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 31
Reset counter: 51
Mileage: 112580 km
Time Indication: 0
Date: 2010.10.13
Time: 19:28:37
Component: SDAR
VCID: 2648736EE88F
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 224
Mileage: 132292 km
Time Indication: 0
Date: 2011.05.18
Time: 09:59:14
VCID: 356AA4222529
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 49
Reset counter: 0
Mileage: 111403 km
Time Indication: 0
Date: 2010.07.23
Time: 12:11:50
Freeze Frame:
Bin. Bits: 0100
Coding: 0423997
VCID: 2C5C8146F663
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 227
Mileage: 145286 km
Time Indication: 0
Date: 2011.11.08
Time: 08:47:33
Revision: C63C0030
Coding: 0005022
VCID: DDBA9C827D59
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 9
Mileage: 153512 km
Time Indication: 0
Date: 2012.02.21
Time: 19:03:12
Freeze Frame:
Voltage: 13.25 V
Count: 236
VCID: 234E6A7A9BBD
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 132289 km
Time Indication: 0
Date: 2011.05.17
Time: 10:11:34
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 117360 km
Time Indication: 0
Date: 2010.11.20
Time: 15:35:15
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Mileage: 151652 km
Time Indication: 0
Date: 2012.01.30
Time: 04:43:26
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 132289 km
Time Indication: 0
Date: 2011.05.17
Time: 10:11:14
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 152165 km
Time Indication: 0
Date: 2012.02.06
Time: 16:45:09
The ABS and Parking brake problems seem to be a common problem at 70,000 miles plus...have the same thing, not to mention my mmi went out for the second time along with my second oil leak. Smh.
chinese parts for our Audi's and I've noticed a few dealers will go that direction. Also, did Audi authorize the last head unit since it needs to be config'd in the sys computer, not really a shade tree job.
What oil leak?
Interesting older German mod you'd like..he's still around and may have some answers to help ya.
http://www.stromgmbh.de/carpc/
Today my car has been having trouble shifting. I've read that this could be the a bad/old battery or being caused by the ABS module. Basically the car has put itself into "limp" mode. Has anyone else experienced this same thing?
Note: no lights were on on my dash when this happened...
Were you able to fix your issue? any input would be great! Thank you.
I've somthing similar, ESP light, trouble shifting in auto, go to tip and its fine. Light goes out after a restart. I think its the battery. I posted this elewhere:
I have a series of faults similar to this that seem to have occured together. It started with the four quiescent current faults as in the first post, I ignored them as they didn't set off any lights, and were probably due to replacing the battery with a secodhand one which had plenty of life in it, but old nonetheless (08). The new faults are a coulple of throtle actuator and angle sensor ones, the clue in the first one is the recorded voltage of 9.779 and the under voltage statement. These in themselves are not an issue, but I also have an ESP fault which lights the dash lamps, and wont go out until I stop the car, ignition off, then start and resume and it goes off after a few hundred yards. I'm guessing all these are related to the battery condition in the first stages after starting, though it can happen well into a drive when you would expect the battery voltage to be OK. The ESP fault is sporadic as are the others, so it has to be something temporary, rather than a faulty component. Heres the fault logs and some block readings from the battery regulator controller and the ABS controller. The throttle actuator one is recorded at 95 RPM which is cranking speed on starting, hence the low voltage, the other two kick in at 106KPH and when the engine temp is 96. The ABS one is related to another fault code found in the engine ECM, they all happen at the same time.
The values from the battery regulator measuring blocks dont give me much of a clue, I don't know how to interpret the measuring block three reading for battery (ageing) with a reading of 0Ah. The Next blocks are from the ABS, the only curious one here is the lateral acceleration of -.19M/s/s, which is a change of speed from 0 to 8 inchs per second over a period of one second. The car was stationary, so shouldn't this be zero. Any help is appreciated.
EDIT. No figures for A6 on VCDS website but Lateral acc. figures for A8 are +-. 5, so -.19 would seem well in spec. My money's on the battery, hard to justify a new one when the old one never fails to start.
75- Throttle Actuator (J338)
P1564 - 002 - Under-Voltage during Basic Setting - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 193346 km
Time Indication: 0
Freeze Frame:
RPM: 95 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 6.0°C
Temperature: 6.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 9.779 V
000545 - Angle Sensor 2 for Throttle (G188)
P0221 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 193346 km
Time Indication: 0
Date: 2015.03.16
Time: 10:09:09
Freeze Frame:
RPM: 2457 /min
Load: 50.2 %
Speed: 109.0 km/h
Temperature: 96.0°C
Temperature: 21.0°C
Voltage: 13.589 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 193346 km
Time Indication: 0
Date: 2015.03.16
Time: 10:09:11
Freeze Frame:
RPM: 2154 /min
Load: 50.6 %
Speed: 107.0 km/h
Temperature: 96.0°C
Temperature: 21.0°C
Voltage: 13.716 V
Address 61: Battery Regul. (4F0 910 181 E)
14:23:40 Group 004: Battery Status II
-0.8 A Current Value from Battery
-0.01 Static-Current Mean Value
10009 Ah Total Energy Balance
10000 Ah Total Energy Throuput
14:23:40 Group 005: Last Standing Time && Last Driving Cycle I
-0.02 Static-Current Mean Value
-0.62 Total-Current Mean Value
1.5 Duration last Standing Time
0.00 Duration last Driving Cycle
14:23:40 Group 006: Last Standing Time && Last Driving Cycle II
0.0 Duration last Standing Time
0.69 Energy Balance of last Drive
50.0 % Battery State of Charge (SOC)
N/A
14:24:10 Group 001: Basic Functions
14.30 V Generator Voltage (specified)
13.90 V Battery Voltage (actual)
38.7 % Dynamic-Field Signal
3.00 s Load Response Time
14:24:10 Group 002: Battery Temperatures && Shut-Off Stages
26.0°C Rail Temperature (actual)
9.5°C Battery Temp. (valuation)
ConsSwOff 0 Emergency Shut-Off
StatCurStg 0 Static-Current Shut-Off Stage
14:24:10 Group 003: Battery Status I
100.0 % Battery Condition
5 ohms Internal Battery Resistance
0 Ah Qv (Battery Aging)
5 Ah Charge
Address 03: ABS Brakes (4F0 910 517 AC)
14:26:49 Group 001: Wheel Speed
0.0 km/h Wheel Speed Front Left
0.0 km/h Wheel Speed Front Right
0.0 km/h Wheel Speed Rear Left
0.0 km/h Wheel Speed Rear Right
14:26:49 Group 002: Switches && Buttons
0.0 Brake Test Switch
0.0 Brake Light Switch
0.0 Parking Brake Button
0.0 ESP-Passive Button
14:26:49 Group 005
-2.5° Steering Angle Sensor (G85)
0.00°/s Turn Rate
-0.33 bar Brake Pressure
-0.19 m/s*2 Lateral Acceleration
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 193346 km
Time Indication: 0
Freeze Frame:
RPM: 95 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 6.0°C
Temperature: 6.0°C
Voltage: 9.779 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 193346 km
Time Indication: 0
Date: 2015.03.16
Time: 10:09:09
Freeze Frame:
RPM: 2457 /min
Load: 50.2 %
Speed: 109.0 km/h
Temperature: 96.0°C
Temperature: 21.0°C
Voltage: 13.589 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 193346 km
Time Indication: 0
Date: 2015.03.16
Time: 10:09:11
Freeze Frame:
RPM: 2154 /min
Load: 50.6 %
Speed: 107.0 km/h
Temperature: 96.0°C
Temperature: 21.0°C
Voltage: 13.716 V
N/A
5 Ah Charge
14:26:49 Group 005
0.00°/s Turn Rate
LarryJa
01-24-2020 04:28 AM
Ian Taylor
New Member Welcome Area
11-22-2017 11:39 PM
