ESP, ABS & Parking Brake lights are up!
All those lights have come up twice for me now.
Present scan:
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H04 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
Shop #: WSC 02327 785 00200
VCID: 2D577FEFB493EC7600B-8078
1 Fault Found:
01420 - High Pressure Switch Valve 1 for Electronic Stability Program (N227)
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 82
Mileage: 255138 km
Time Indication: 0
Date: 2016.07.06
Time: 17:51:02
Freeze Frame:
Hex Value: 0x3900
Hex Value: 0x4006
Hex Value: 0x0018
Hex Value: 0xB8A6
Hex Value: 0x00FF
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
Shop #: WSC 02334 785 00200
VCID: DDB76F2F04B3DCF650B-8088
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 2
Reset counter: 82
Mileage: 255136 km
Time Indication: 0
Date: 2016.07.06
Time: 17:51:04
Freeze Frame:
Voltage: 12.63 V
Count: 236
So, what do I need to replace/repair to fix this? ABS control module? Pump?
Present scan:
Coding: 0020895
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 82
Mileage: 255138 km
Time Indication: 0
Date: 2016.07.06
Time: 17:51:02
Freeze Frame:
Hex Value: 0x3900
Hex Value: 0x4006
Hex Value: 0x0018
Hex Value: 0xB8A6
Hex Value: 0x00FF
Revision: C63C0030
Coding: 0005022
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 82
Mileage: 255136 km
Time Indication: 0
Date: 2016.07.06
Time: 17:51:04
Freeze Frame:
Voltage: 12.63 V
Count: 236
Ross Tech wiki says it's a module or connection issue.
So, it's not going to be a big hassle of changing the pump & bleeding the brake system. That'd be a real pain.
It's an intermittent.
So, i decided to "excercise" the switch.
I found a damp stretch of road & slammed the brakes on. That kicked the abs on, & the alert has not returned since.
My thought was to affect a HP switch by exceeding any threshold set for the switch. So far, so good.
Earlier, I found that the alert would clear the next time that I turned on the ignition. After that, I'd clear rhe faults with vcds.
If they return, I'll replace the abs control module.
Hi I'm getting a lot of dash lights on for a while related to brake (ABS/Parking/ESP) . (See fault codes below). Have read that maybe I need to replace ABS module DIY from CheapABS - has any one had these codes and how did you solve? Thank you:
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 560 E HW: 4F0 907 559
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number:
Coding: 0007772
Freeze Frame:
Readiness: 0000 0000
RPM: 879 /min
Self-Diagnosis Log
Thursday,23,January,2020,14:29:55:60248
Found: 18061 - Please check DTC Memory of ABS Controller P1653 - 008 - - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 177 Reset counter: 255
Mileage: 260554 km
Time Indication: 0 Date: 2019.09.14 Time: 16:40:23
Load: 30.6 %
Speed: 2.0 km/h
Temperature: 50.0°C Temperature: 39.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.716 V
Address 03: ABS Brakes Labels: 4F0-910-517.clb PartNoSW:4F0910517L HW:4F0614517L Component: ESP 8.0 quattro H04 0090 Revision: 00000000 Serial number: 00000000000000 Coding: 0021352 Shop #: WSC 02327 785 00200
1 Fault Found: 01418 - Switch Valve 1 for Electronic Stability Program (N225) 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 1 Fault Frequency: 137 Reset counter: 54 Mileage: 263824 km
Time Indication: 0 Date: 2019.10.26 Time: 10:32:48
Hex Value: 0x6700
Hex Value: 0x4006
Hex Value: 0x0016
Hex Value: 0xB8B0
Hex Value: 0x00FF
Coding: 0007772
Freeze Frame:
RPM: 879 /min
Self-Diagnosis Log
Mileage: 260554 km
Load: 30.6 %
Speed: 2.0 km/h
Voltage: 13.716 V
Hex Value: 0x6700
Hex Value: 0x4006
Hex Value: 0x0016
Hex Value: 0xB8B0
Hex Value: 0x00FF
