Extended Crank?
Same here, I posted a thread on it a while back.
Took the car in for a manual carbon cleaning - didn't help
Replaced the fuel filter - didn't help
Replaced the battery (it was 6yrs old so it was time anyway) - didn't help
Took it to another dealer today to have them look at it. Apparently they performed some adaptation, which might have been this: http://uberlame.com/a6_tsb/Engine/En...ong%20Time.pdf and it apparently fixed the issue. I have tried following the TSB myself before, but it wasn't really working for me.
At one point they also thought it might be a leaky injector, but they tested the injectors and all was fine.
I'll let you know tomorrow when I start the car in the morning if the adaptation they performed really fixed the problem, I certainly hope it did!
Starting the car this morning I have to say that I'm disappointed because I don't think what ever the dealer did really helped.
I'm going to take a quick video next time I'm starting the car cold. carwash, can you do the same so we can compare?
i always had 3-5 sec crank when cold...on all my cars....you find it not normal??..
when my car is hot it starts direct...but when cold...i count it to start later...never see that as a issue..
/H
/H
I have that but I too consider it to be normal behavior for a cold start.
It's not a carbureted engine. There is no need for extended crank even on coldstart regardless of temperature et cetera. Especially on a car with fuel delivery technology as amazing as this car.
