Faults found before MMI update
So, having read loads about updating my MMI 2G to 5570 and been advised to get a VCDS log of the system which I did, I've found some disturbing fault codes!!!
Can anyone suggest my next course of action as I've had 2 differing opinions so far
1) Renew battery regulator
2) Maybe a control unit has lost it's code and the other faults are due to low battery.
I'd be grateful for any input
Thanks in advance
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 34 37 42 46 47 4F 52
53 55 56 61 62 69 6C 6D 72 76 77
VIN: WAUZZZ4F67N137762 Mileage: 177900km/110541miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
34-Level Control -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 402 A HW: 4F0 907 401 C
Component: 3.0L V6TDI G000AG 0030
Revision: --H04--- Serial number:
Coding: 0011372
Shop #: WSC 02334 785 00200
VCID: 1B3E529AA3CD
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F2 910 156 K HW: 09L 927 156 C
Component: AG6 09L 3,0 TDI RdW 0040
Revision: --H01--- Serial number: 4299107
Coding: 0000001
Shop #: WSC 02325 785 00200
VCID: 2D5A8C42CD79
1 Fault Found:
006246 - Powertrain Data Bus: Missing Messages
P1866 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 64 /min
RPM: 32 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 15.0°C
T.B. Angle: 60.0°
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AB HW: 4F0 614 517 R
Component: ESP 8.0 quattro H05 0040
Revision: 00000000 Serial number: 00000000000000
Coding: 0000392
VCID: 64CC2966DE33
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100705822
Coding: 0000131
Shop #: WSC 02323 785 00200
VCID: E3CEAA7A5B3D
Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 731 S HW: 4E0 035 729 A
Component: Interfacebox H43 3450
Revision: 00000000 Serial number: 351BG077535411
Coding: 0003002
Shop #: WSC 40330 222 83441
VCID: 32609F3ED447
Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000030219659
Coding: 0002326
VCID: 1C3C5186A6C3
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0012122
Shop #: WSC 02335 785 00200
VCID: 31629032D141
Part No: 4F1 910 113 C
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H44 0350
Revision: 00044000 Serial number: AUZ5ZBG3177643
Shop #: WSC 00000 000 00000
VCID: 18344D9652FB
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 42 AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0PD1YV
Coding: 0013362
VCID: 29527852F991
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0410
Revision: 00H03000 Serial number: 90054070130428
Coding: 0002342
VCID: 27567E6AEF85
Part No: XXXXXXXXXXX
Component: E0221 H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 932
Component: KOMBIINSTR. M73 H20 0170
Revision: 00200000 Serial number: 5HP1A7137
Coding: 6185148
Shop #: WSC 40330 222 180054
VCID: 234E6A7A9BBD
Address 18: Aux. Heat Labels: None
Part No SW: 4F0 910 105 A HW: 4F0 265 081 L
Component: Heizgeraet H08 0060
Revision: C Serial number: 09011480
Coding: 0000111
VCID: 1B3E529AA3CD
2 Faults Found:
01233 - Engine Coolant Blocking Valve for Heater (N279)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 93
Mileage: 170040 km
Time Indication: 0
Date: 2010.12.14
Time: 18:50:25
Freeze Frame:
Start
Temperature: -4.0°C
Temperature: -4.0°C
00664 - Fuel gauge
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 6
Reset counter: 94
Mileage: 170051 km
Time Indication: 0
Date: 2011.01.14
Time: 11:18:33
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B073020005
Coding: F759FE7F303206
Shop #: WSC 40330 222 81127
VCID: ECDCC146B6E3
Address 34: Level Control Labels: None
Part No SW: 4F0 910 553 A HW: 4F0 907 553 A
Component: J197 LUFTFEDER H17 0060
Serial number: 00619002917700
Coding: 0000220
VCID: 22406F7E84A7
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 L
Component: MNS ECE H48 1060
Revision: 00000000 Serial number: 364CN077647103
Shop #: WSC 40330 222 55049
VCID: 3B7EB21A030D
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 P HW: 4F0 959 793 P
Component: TSG FA H12 0230
Revision: 00000000 Serial number: "cV
Coding: 0003626
Shop #: WSC 02327 785 00200
VCID: 3776AE2A3F25
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 B HW: 4F0 907 289 B
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01035673390000
Coding: 3351281
VCID: 29527852F991
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 47: Sound System (J525) Labels: None
Part No SW: 4F0 910 223 H HW: 4F0 035 223 K
Component: Amp.-ASK-RD H07 0130
Revision: 08S00000
Coding: 080001
Shop #: WSC 02399 823 56573
VCID: 234E6A7A9BBD
6 Faults Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 170052 km
Time Indication: 0
Date: 2011.01.17
Time: 10:37:45
Freeze Frame:
Voltage: 11.00 V
Temperature: 7.0°C
Bin. Bits: 00000111
00420 - Right Front DSP Midrange Speaker (R104)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 170052 km
Time Indication: 0
Date: 2011.01.17
Time: 10:37:45
Freeze Frame:
Voltage: 11.00 V
Temperature: 7.0°C
Bin. Bits: 00000111
00871 - Bass Speaker Front Right (R23)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 170052 km
Time Indication: 0
Date: 2011.01.17
Time: 10:37:45
Freeze Frame:
Voltage: 11.00 V
Temperature: 7.0°C
Bin. Bits: 00000111
00419 - Left Front DSP Midrange Speaker (R103)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 170052 km
Time Indication: 0
Date: 2011.01.17
Time: 10:37:45
Freeze Frame:
Voltage: 11.00 V
Temperature: 7.0°C
Bin. Bits: 00000111
02558 - Left Rear Mid-Range/Woofer Loudspeaker (R159)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 170052 km
Time Indication: 0
Date: 2011.01.17
Time: 10:37:45
Freeze Frame:
Voltage: 11.00 V
Temperature: 7.0°C
Bin. Bits: 00000111
02559 - Right Rear Mid-Range/Woofer Loudspeaker (R160)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 170052 km
Time Indication: 0
Date: 2011.01.17
Time: 10:37:45
Freeze Frame:
Voltage: 11.00 V
Temperature: 7.0°C
Bin. Bits: 00000111
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000404351
Coding: 0001103
VCID: DEB89B8E705F
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 P HW: 4F0 959 792 P
Component: TSG BF H12 0230
Revision: 00000000 Serial number: HrV
Coding: 0003626
VCID: 3776AE2A3F25
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0000321
Shop #: WSC 02324 785 00200
VCID: 204465768AAB
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000004
VCID: 3D7ABC021D19
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 161
Mileage: 170040 km
Time Indication: 0
Date: 2010.12.22
Time: 09:46:02
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394C$077746386
Coding: 0000001
VCID: 2E588B4EC07F
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000032866
VCID: 234E6A7A9BBD
Part No: 4F0 915 105 E
Component: von VA0 570228S07F
Coding: 344630393135313035452056413035373032323853303746
Shop #: WSC 00000 384 00290
5 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 74
Mileage: 135010 km
Time Indication: 0
Date: 2009.12.21
Time: 09:37:13
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 46
Mileage: 135629 km
Time Indication: 0
Date: 2010.01.03
Time: 12:35:43
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 41
Mileage: 135629 km
Time Indication: 0
Date: 2010.01.03
Time: 12:35:54
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 40
Mileage: 135629 km
Time Indication: 0
Date: 2010.01.03
Time: 12:36:04
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 39
Mileage: 135629 km
Time Indication: 0
Date: 2010.01.03
Time: 12:36:14
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0003114
VCID: 2E588B4EC07F
Address 69: Trailer Labels: 4F0-910-383.lbl
Part No SW: 4F0 910 383 B HW: 4F0 907 383 B
Component: ANHAENGERELEKTR 003 0060
Coding: 0000331
VCID: 244C69669EB3
1 Fault Found:
02564 - Trailer; Left Tail Lamps (M60)
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 167256 km
Time Indication: 0
Date: 2010.11.01
Time: 09:18:00
Address 6C: Back-up Cam. Labels: 4L0-910-441.lbl
Part No SW: 4F0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J6Z305I
Coding: 1030205
VCID: 1E385B8EB0DF
Address 6D: Trunk Elect. Labels: Redir Fail!
Part No SW: 4F9 910 591 HW: 4F9 827 851 E
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: ECDCC146B6E3
Part No: 4F9 910 592
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0003114
VCID: 2E588B4EC07F
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
Component: Parkhilfe 8-Kan H12 0060
Revision: 00H12000 Serial number: 06330705907962
Coding: 0231416
Shop #: WSC 131071 1023 2097151
VCID: 28547D56E29B
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 A HW: 4F1 862 335
Component: BTA H10 0710
Revision: 00H10000 Serial number: 00000007561074
Coding: 0050021
VCID: 22406F7E84A7
Thanks in advance
Chassis Type: 4L0
Coding: 0011372
VCID: 1B3E529AA3CD
Coding: 0000001
VCID: 2D5A8C42CD79
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 64 /min
RPM: 32 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 15.0°C
T.B. Angle: 60.0°
Coding: 0000392
VCID: 64CC2966DE33
Coding: 0000131
VCID: E3CEAA7A5B3D
Coding: 0003002
VCID: 32609F3ED447
Coding: 0002326
VCID: 1C3C5186A6C3
Coding: 0012122
VCID: 31629032D141
Coding: 00064784
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
VCID: 18344D9652FB
Coding: 0013362
VCID: 29527852F991
Coding: 0002342
VCID: 27567E6AEF85
Coding: 6185148
VCID: 234E6A7A9BBD
Coding: 0000111
VCID: 1B3E529AA3CD
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 93
Mileage: 170040 km
Time Indication: 0
Date: 2010.12.14
Time: 18:50:25
Freeze Frame:
Start
Temperature: -4.0°C
Temperature: -4.0°C
00664 - Fuel gauge
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 94
Mileage: 170051 km
Time Indication: 0
Date: 2011.01.14
Time: 11:18:33
VCID: ECDCC146B6E3
Coding: 0000220
VCID: 22406F7E84A7
VCID: 3B7EB21A030D
Coding: 0003626
VCID: 3776AE2A3F25
Coding: 3351281
VCID: 29527852F991
Revision: 08S00000
Coding: 080001
VCID: 234E6A7A9BBD
6 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 170052 km
Time Indication: 0
Date: 2011.01.17
Time: 10:37:45
Freeze Frame:
Voltage: 11.00 V
Temperature: 7.0°C
Bin. Bits: 00000111
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 170052 km
Time Indication: 0
Date: 2011.01.17
Time: 10:37:45
Freeze Frame:
Voltage: 11.00 V
Temperature: 7.0°C
Bin. Bits: 00000111
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 170052 km
Time Indication: 0
Date: 2011.01.17
Time: 10:37:45
Freeze Frame:
Voltage: 11.00 V
Temperature: 7.0°C
Bin. Bits: 00000111
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 170052 km
Time Indication: 0
Date: 2011.01.17
Time: 10:37:45
Freeze Frame:
Voltage: 11.00 V
Temperature: 7.0°C
Bin. Bits: 00000111
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 170052 km
Time Indication: 0
Date: 2011.01.17
Time: 10:37:45
Freeze Frame:
Voltage: 11.00 V
Temperature: 7.0°C
Bin. Bits: 00000111
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 170052 km
Time Indication: 0
Date: 2011.01.17
Time: 10:37:45
Freeze Frame:
Voltage: 11.00 V
Temperature: 7.0°C
Bin. Bits: 00000111
Coding: 0001103
VCID: DEB89B8E705F
Coding: 0003626
VCID: 3776AE2A3F25
Revision: --H04---
Coding: 0000321
VCID: 204465768AAB
Coding: 0000004
VCID: 3D7ABC021D19
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 161
Mileage: 170040 km
Time Indication: 0
Date: 2010.12.22
Time: 09:46:02
Coding: 0000001
VCID: 2E588B4EC07F
VCID: 234E6A7A9BBD
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 74
Mileage: 135010 km
Time Indication: 0
Date: 2009.12.21
Time: 09:37:13
Freeze Frame:
Fault Priority: 7
Fault Frequency: 46
Mileage: 135629 km
Time Indication: 0
Date: 2010.01.03
Time: 12:35:43
Freeze Frame:
Fault Priority: 7
Fault Frequency: 41
Mileage: 135629 km
Time Indication: 0
Date: 2010.01.03
Time: 12:35:54
Freeze Frame:
Fault Priority: 7
Fault Frequency: 40
Mileage: 135629 km
Time Indication: 0
Date: 2010.01.03
Time: 12:36:04
Freeze Frame:
Fault Priority: 7
Fault Frequency: 39
Mileage: 135629 km
Time Indication: 0
Date: 2010.01.03
Time: 12:36:14
Coding: 0003114
VCID: 2E588B4EC07F
Coding: 0000331
VCID: 244C69669EB3
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 167256 km
Time Indication: 0
Date: 2010.11.01
Time: 09:18:00
Coding: 1030205
VCID: 1E385B8EB0DF
VCID: ECDCC146B6E3
Coding: 0003114
VCID: 2E588B4EC07F
Coding: 0231416
VCID: 28547D56E29B
Coding: 0050021
VCID: 22406F7E84A7
clear away the fault codes...the battery regulator latest fault is 2010.01.03....
and they are btw "Intermittent"..so no need to worry..
i had also lots of faults on battery regulator when my battery didn't have enough current...
/H
/H
