folding side mirrors
#31
At the very least, it would be nice to allow the fold switch to work when the car is off. Often times, i turn the car off before folding the mirror, and have to put the power back on just to fold them.
#33
has to be a relay somewhere.
my 'wish' would be for it to auto-fold when i put the gear in Park, and then unfold when i start the engine.
if it's doable in newer models.. it can be done.
#35
Hi guys,
I found the following site and have been attempting to do this on my C6: http://www.audienthusiasts.com/Proje...gMirrors4.html
However, I'm trying to long code aspects of module 46 (central convenience) and don't see 'long coding' as an option.
It states I'm supposed to do the following:
Enabling MMI Menu for Folding Mirrors
[46 - Central Conv.]
[Coding - 07] -> [Long Coding Helper] -> Byte 7 Bit -> 7 Change 0 to 1
Or Check the box for "Foldable Mirrors Installed "
I already have folding mirrors, however trying to enable this as part of the un/lock and the coding explicitly walks through long coding.
#37
This is not an easy solution.
I've been trying to find out how to do this and I've come across some 'walls':
There is NO long coding, however if you or someone has a contact @ Rosstech who can confirm if there is a workaround for this...that would be a win
We need some sort of relay to 'trip' the actual close/opening. There's been some threads on the VW forums about doing this via the door lock relay.
I'm still hoping for someway to do this...but not VERY hopeful at this point
#38
No auto fold mechanism on the 2000 A6 Quattro, brought to mind a couple hours ago when I parked on the street to run some errands. Came back to the car to find the mirror smashed and hanging from one of the heater connectors, and the housing knocked forward.
It was a good thing the housing isn't rigid, as that likely saved the whole thing from being knocked off.
Don't know if it was pure vandalism or a hopelessly inept driver passing by. I can only hope it returned the favor to their own mirror.
Maybe if I took the time to manually fold it in, it may not have happened, but one can only speculate. Really would have like to find out the culprit.
At least it should only need a replacement glass to restore to working order; planning to get a simple generic glass instead of the autodimming one which had already started turning blotchy. Maybe the miscreant did me a favor, as I was considering replacing the glass anyway to restore a clear view.
On the power mirror subject, I also had the snapped power mirror switch stalk issue, which I actually went and repaired by drilling out the center of the stub and threading in a metal stem, should prove much more durable than Audi's original plastic design. Can't figure out why they thought plastic for cost cutting would be a good idea for that type of setup. ebay apparently shows that the number of broken Audi mirror switches makes it worthwhile coming up with replacement switch clones.
So if you have a busted switch from the flimsy stalk snapping off at the base, hang on it and just repair it, pretty easy process.
#39
Yeah, I was in France this summer and I used the folding mirror option. Even used it once on a very narrow country road so that I could clear oncoming traffic. I got the hint when the guy coming at me folded his mirror in and we passed each other very slowly. LOL.
Raiden256
A6 (C7 Platform) Discussion
28
12-10-2015 02:50 AM
Ford576
09-10-2015 12:38 PM
Vrrooom
09-08-2015 03:06 PM
