A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Front brake wear uneven question
Old 04-13-2014, 06:25 PM
  #11
haloguy628's Avatar
Use high temp lithium based grease.
Old 04-14-2014, 03:09 AM
  #12
uberwgn's Avatar
Originally Posted by tenspeed
Even well lubricated pins wear out. I just ordered a third set for a 130K mile car.
Thanks for the tip on that. I started ordering new brake components last night. I'll ensure I get new pins, too. Do we know the part number for the pins?
Old 04-14-2014, 05:16 AM
  #13
Costasz's Avatar
Default Well, the pads did not exhibit angled wear
Worn piston side pads indicates the caliper is not sliding on the pins. It slides enough to stop the car but when pressure is released, the piston side pad rides on the rotor instead of backing off.
Angled pad wear indicates that one side is sliding more than the other.
Touch the front wheels after a long drive. If one side is hotter, the brake is dragging. Even well lubricated pins wear out. I just ordered a third set for a 130K mile car.
They were evenly worn. The car only hit 40K miles. I think the previous installer neglected to grease them as I did not see any grease on the bolts. I saw a little bit of black sticky residue but that resembled grime more than grease. What would pin wear look like? I mean, the pins I took out looked shiny when the grime was cleaned off, there were a few scratched on them but very superficial.
Old 04-15-2014, 06:06 PM
  #14
KnappAttack's Avatar
I ran for 140,000 miles using stock components, not the originals but stock pads and discs, never had this happen. The minute the Akebonos went in, I've had uneven wear on the pads.
I'd agree that stuck caliper causes uneven wear, but I know my calipers are not stuck or binding.
Britpoptwo
Q5/SQ5 MKI (8R) Discussion
01-27-2018 03:47 PM
highmiles
06-18-2013 12:57 PM
BigBobELK
12-09-2008 04:23 PM
Gray Bush
10-03-2008 01:18 PM
tankman86
09-02-2003 05:12 PM
Quick Reply: Front brake wear uneven question
