Fuel filter change, Do I need Vag-com?
Ok looking at doing a little maintenance on the car at about 75k miles. I'm thinking I should replace the fuel filter while i'm at it. Will I need a Vag-Com for removing an error code when pulling the 20amp fuse and turing on the key to reduce the pressure?
Reason I ask is because I don't have a vag-com and doesn't seem anyone in town can clear any service stuff even for oil changes.
Although there will be a couple of DTCs when you pull the fuse and run out of gas, you don't really need VAG–COM. These DTCs will not illuminate the CEL, so there is no harm. Hope you have better luck than I did getting the hoses released from the filter.
Also at 30k miles mine looked like new when I cut it open...might be that I have relatively clean gas in my area, but I'd assume you could easily go 100k+ miles given the size of the filter. Unless of course you truly suspect it is clogged.
heatsoakedS4
06-06-2008 09:48 PM
mmart6545
11-21-2004 07:03 PM
