A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
G247 fuel pressure sensor problems
Old 03-20-2022, 01:39 PM
  #11
Tim Baker's Avatar
Originally Posted by Jonlereux
Thanks for the reply, I am at a loss at this point since it went from running with no issues to running like dog crap. I will be looking at vacuum lines next. I would hate to find out my ECU is the culprit, but it would be my luck.
I DO remember what fixed it. my LOW PRESSURE FUEL PUMP. the electric in tank pump was bad and so was the control module on the top of the tank! I got replacements from a junk yard!
Old 03-20-2022, 01:41 PM
  #12
Tim Baker's Avatar
Originally Posted by Tim Baker
here is a scope describing the fuel pressure readings i'm getting. as I said I've replaced the HPFP. the G247 sensor is over 100 USD I hate to replace it for no reason... any advice anyone?
yellow is fuel pressure actual, green is spec, red is engine speed. you can see shortly after it reports 0 fuel pressure for a millisecond it stalls...
The square waves were indicative of when the fuel pump control module above the electric pump ontop of the tank, under the backseat was failing and giving faulty readings.
Jonlereux (03-20-2022)
Old 03-20-2022, 04:36 PM
  #13
Jonlereux's Avatar
To answer what i have experienced
My car is stumbling at idle. My wagon was running fine and it started randomly during a cold spell this winter
Since performing the repairs below, it was driving normally other than poor idle but seems to be getting worse.
My primary codes latched are intake air leak and high fuel rail pressure as well as the misfire codes that come with the previous codes. I have been unsuccessful in finding the source of my air/ vacuum leak
So far I have replaced the PCV valve, HP fuel pump, injectors, coils, spark plugs, intake gaskets, all fuel related sensors, all intake sensors, have performed a smoke test attempting to find a leak without any success
I was leaning towards lpfp however i have not replaced the low pressure fuel pump yet since I haven't resolved my vacuum leak. I am starting to believe my vacuum/air leak is coming from a faulty rear main seal.
I do have a lot of carbon build up at the intake,/ exhaust valve port area but I didn't want to dig into that unless I had to since it was driving fine until recently.
I have ordered a billet rear seal since the seal seems to be a weak link of this engine design however I am not looking forward to pulling the engine to perform the repair since my garage space is limited and would be a pain to have a car taking up space for too long.
I will post my findings however I suspect it will be a while before I muster the courage to pull the engine to replace the rear seal since I will feel obligated to repair/ replace any other maintenance items while the engine is out; seals, hoses, water pump, walnut blasting heads, etc.
Its been frustrating to say the least.
I do appreciate the input though, so thanks
Old 03-14-2023, 03:20 PM
  #14
KoJackee's Avatar
Jonlereux, did you find what was the problem? I am having a similar issue?
Itsjdmyo
Q5/SQ5 MKI (8R) Discussion
01-17-2019 10:03 AM
XMetal00
Audi A3 / S3 / RS 3 MKII
05-17-2018 09:21 AM
B490MTL
Q7 MK 1 Discussion
03-19-2016 02:35 PM
ablankS4
11-13-2007 01:45 PM
BlueS4orce
08-29-2003 02:50 PM
Quick Reply: G247 fuel pressure sensor problems
