H&R Coilovers
#11
check the camber in the rear. It looks a bit slanted in (second pic from the top). When they re-aligned my car, they let out the camber in the front all the way and adjusted the rear so it was straight. I still have to rotate the tires every 2500 miles so the tires don't wear unevenly in the front. Enjoy the new look and be careful of the potholes!
#12
#13
Yea it hasnt had an alignment. It goes in tomorrow.
#14
Spacers are "disks" of metal that go between your wheel hubs and the wheels themselves, thereby making your wheels stick out farther than without spacers. This is generally a visual improvement, but could also be thought of as a performance improvement as it will effectively lower your center of gravity by making your footprint wider. But mostly it just keeps your wheels and tires from hiding way back in the wells. They are also used to make up the difference in offsets of aftermarket and other non-stock spec wheels.
#16
Scooter80 I have to disagree about spacers being an improvement. They are a real hazard in that the car was never designed to have that much length on the wheel bolts and there's a distinct possibility that the bolts will come loose over time. There is also the issue that the whole tire contact patch is moved outward, effectively reducing the spring rate and causing tramlining or pulling to the side when driving over grooved or uneven pavement.
If you want "the look" do it right and get wheels with the correct offset. If you don't care so much for performance and just want to look good, then go for spacers, but please retorque the bolts every week or so.
Just my opinion, I'm sure there's many that feel differently about this.
#18
LOL
#19
For anyone who has H&R coilovers, do you think there should be more room to raise on my setup?
Otherwise, I may be looking for an S6 stock setup to swap out..
Thanks-
