Help with 2005 Audi A6-3.2L quattro BKH
I have replaced the J757 relay, the G410 sensor and N80 valve. I still get the chk engine light like in 2 days or so.
and here is the new scan and there is some new fault code and am hoping the gurus here can help me with this.
Wednesday,30,September,2015,11:16:48:61835
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
Ross-Tech: Home
VIN: WAUDT74F35N047546 License Plate:
Mileage: 210280km-130661mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 72 77
VIN: WAUDT74F35N047546 Mileage: 210280km-130661miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F1 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0040
Revision: --H15--- Serial number:
Coding: 01050106190F0120
Shop #: WSC 25807 444 54393
VCID: 2A5BE460850EA26E23-807E
3 Faults Found:
19502 - Starter Relay 1
P3046 - 006 - Electr. Malfunction in Circuit (Relay Stuck / Does not Switch) - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 35
Mileage: 210124 km
Time Indication: 0
Date: 2015.09.28
Time: 18:16:39
Freeze Frame:
RPM: 1152 /min
Mass Air / Rev.: 141.7 mg/str
Temperature: 97.5°C
Idle
Voltage: 11.73 V
Speed: 0.0 km/h
18975 - Low Pressure Fuel Sensor (G410)
P2543 - 009 - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 7
Reset counter: 40
Mileage: 210131 km
Time Indication: 0
Date: 2015.09.28
Time: 19:11:55
Freeze Frame:
RPM: 672 /min
Mass Air / Rev.: 239.8 mg/str
Temperature: 88.5°C
Idle
Pressure: 4.9 bar
Speed: 0.0 km/h
18836 - EVAP Leak Detection Pump Sense Circuit
P2404 - 006 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 4
Fault Frequency: 2
Reset counter: 40
Mileage: 210146 km
Time Indication: 0
Date: 2015.09.29
Time: 09:47:38
Freeze Frame:
RPM: 1312 /min
Mass Air / Rev.: 114.5 mg/str
Temperature: 78.0°C
Idle
Voltage: 13.57 V
Speed: 40.0 km/h
Readiness: 0000 0100
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 H HW: 09L 927 156
Component: AG6 09L 3.2 FSI USA 0020
Revision: --H01--- Serial number: 0048342
Coding: 0001002
Shop #: WSC 02335 785 00200
VCID: 29591B6C8008A9762A-807C
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 E HW: 4F0 614 517 A
Component: ESP8 quattro H03 0010
Revision: 00000000 Serial number: 00000000000000
Coding: 0004511
VCID: 264310509116860E07-8072
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0130
Revision: 30040401 Serial number: 10600300069238
Coding: 0000011
Shop #: WSC 25105 444 54636
VCID: 63C54944A2A4332620-8036
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H43 0070
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H35 0040
1 Fault Found:
00955 - Key 1
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 55
Mileage: 210135 km
Time Indication: 0
Date: 2015.09.28
Time: 21:21:00
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 732 Q HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 360IQ047504466
Coding: 0000003
Shop #: WSC 04352 001 1048576
VCID: 3169F30CA8D8D1B6E2-8064
Subsystem 1 - Part No: 4F0 910 609
Component: Bedienteil MMIC6H07 0870
Subsystem 2 - Serial number: 00000000052016
Subsystem 3 - Serial number: 0108.09.040000000100010018ÿ
Subsystem 4 - Serial number: 010018ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 H
Component: KLIMABETAETIGUNGH11 0110
Revision: 00000023 Serial number: 00000000056135
Coding: 0524326
VCID: 5BB571A49AD40BE668-800E
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0013123
VCID: 66C350505196460EC7-8032
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD6007427
Shop #: WSC 00000 000 00000
VCID: 1C3732B8DF5A4CDEA1-8048
Address 0F: Digital Radio
Cannot be reached
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 B HW: 4F0 959 655 A
Component: 56 AIRBAG AUDI8RH28 0310
Revision: 09H28000 Serial number: 00359D071N9R
Coding: 0013622
Shop #: WSC 05141 444 83913
Subsystem 1 - Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
Subsystem 2 - Serial number: 6332CSME057858598
Subsystem 3 - Serial number: 6342CSME06524A0D2
Subsystem 4 - Serial number: 6351HSME036A4023
Subsystem 5 - Serial number: 6361HSME037C42523
Subsystem 6 - Serial number: 6371VSME0364180CH
Subsystem 7 - Serial number: 6381VSME03755A72N
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026042540234
Coding: 0002041
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H05 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H09 0460
Revision: 00100000 Serial number: 4I275XD94
Coding: 0065263
Shop #: WSC 25105 444 84543
VCID: 1E3338B0C9465ECE4F-804A
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 08008048180364
Coding: 6CFE73CC1B3904
VCID: 275D1D54961C9F063C-8072
1 Fault Found:
02230 - Digital Radio (DAB) (R147)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 15
Mileage: 210124 km
Time Indication: 0
Date: 2015.09.28
Time: 18:16:47
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082946
VCID: 61C9434CB8B8213632-8034
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H43 1100
Revision: 00000000 Serial number: 378IP047501450
VCID: 387FCE284BA200FEA5-806C
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H10 0020
Revision: 00000000 Serial number: ‘
Coding: 0035563
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01000810860000
Coding: 0423997
VCID: 2C57E2788FFABC5ED1-8078
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Address 47: Sound System Labels: None
Part No SW: 4F5 910 223 F HW: 4F5 035 223 E
Component: DSP-High C6 H14 0330
Revision: PROD_01 Serial number: 00000000007747
Coding: 0000016
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H07 0040
Revision: Serial number: 00000000030599
Coding: 0001114
VCID: 5EB378B089C61ECE0F-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H10 0020
Revision: 00000000 Serial number: W
Coding: 0035563
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0005022
Shop #: WSC 00001 000 00000
VCID: 2149034CF838613672-8074
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 A HW: 4F0 907 357 A
Component: AFS 1 H03 0010
Revision: 00000001 Serial number:
Coding: 0000016
Shop #: WSC 02325 785 00200
VCID: 24470A58E72A741E19-8070
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH05 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 352IU047556615
Coding: 0000002
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0490
Revision: 00000000 Serial number: 00000000051399
VCID: 23450944E224732660-8076
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 1409090118
Coding: 344630393135313035432056413031343039303930313138
Shop #: WSC 12345 640 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H09 0010
Coding: 0035370
VCID: 69D95B6C40886976EA-803C
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H09 0010
Coding: 0035370
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H10 1130
Revision: 00000000 Serial number: 00000007501395
Coding: 0010900
VCID: 285F1E689B02907E35-807C
End-------------------------(Elapsed Time: 02:48)--------------------------
Ross-Tech: Home
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 35
Mileage: 210124 km
Time Indication: 0
Date: 2015.09.28
Time: 18:16:39
Freeze Frame:
RPM: 1152 /min
Temperature: 97.5°C
Idle
Voltage: 11.73 V
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 40
Mileage: 210131 km
Time Indication: 0
Date: 2015.09.28
Time: 19:11:55
Freeze Frame:
RPM: 672 /min
Temperature: 88.5°C
Idle
Pressure: 4.9 bar
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 40
Mileage: 210146 km
Time Indication: 0
Date: 2015.09.29
Time: 09:47:38
Freeze Frame:
RPM: 1312 /min
Temperature: 78.0°C
Idle
Voltage: 13.57 V
Speed: 40.0 km/h
Coding: 0001002
Coding: 0004511
Coding: 0000011
1 Fault Found:
00955 - Key 1
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 55
Mileage: 210135 km
Time Indication: 0
Date: 2015.09.28
Time: 21:21:00
Coding: 0000003
Coding: 0524326
Coding: 0013123
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
Cannot be reached
Coding: 0013622
Coding: 0002041
Coding: 0065263
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 15
Mileage: 210124 km
Time Indication: 0
Date: 2015.09.28
Time: 18:16:47
Coding: 0082946
Coding: 0035563
Coding: 0423997
Coding: 0000016
Coding: 0001114
Coding: 0035563
Revision: --H05---
Coding: 0005022
Coding: 0000016
Coding: 0000002
Coding: 0035370
Coding: 0035370
Coding: 0010900
That looks like a Q5 VIN - wrong forum?
2004A8L
18
01-10-2022 03:04 PM
wantfryswiddat
09-21-2015 05:55 AM
Audi Other 2005 Audi Allroad 4.2L Silver 119k
jbicski
08-30-2015 12:48 PM
Audi A4 Audi A4 A6 Quattro Turbocharger
Rinmike
08-28-2015 12:19 AM
