HELP! Key won't remove. Car won't start.
So the car this morning did not respond to the start/stop button and after attempting to use the key has now locked the key in the ignition. There is no response to turning the key (no dash lights, accessory mode, etc.). It just turns back and forth without releasing. The other electronics in the car work fine (door locks, MMI turns on with volume button, etc.) but no response whatsoever with the key.
I can't run an Auto Scan because the car is not on, but I was able to find the following code below:
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Control Module Part Number: 4F0 910 279 HW: 4F0 907 279
Component and/or Version: ILM Fahrer H14 0080
Software Coding: 0013123
Work Shop Code: WSC 02335 785 00200
Additional Info: Fehler Lin-Slave 01 Fehler Lin-Slave 02
VCID: E6C3FD07D19F592E81B-80B3
00456 - Control Module for Access and Start Control (J518)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 12
This happened once before with thsi exact same key and it inexplicably released hours later. It never happened again (although the key is not the primary driver's) and we kind of forgot about it.
Any ideas??
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 12
Any ideas??
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 12
Any ideas??
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 12
Any ideas??
Auto Scan worked, but the key is still stuck. Below are the scan results...
Tuesday,04,November,2014,06:10:07:63508
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: License Plate: 4 NOV 2-14
Mileage: a6 Repair Order:
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 12
Mileage: 230572 km
Time Indication: 0
Date: 2014.11.04
Time: 06:05:00
01494 - Bulb for Parking Lamps; Left (M1)
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 2
Fault Frequency: 4
Reset counter: 12
Mileage: 230412 km
Time Indication: 0
Date: 2014.11.03
Time: 13:36:00
Address 09: DTCs cleared
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 230572 km
Time Indication: 0
Date: 2014.11.04
Time: 06:15:00
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 65 67 6D 72 76 77
Mileage: 230570km/143269miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: Cannot be reached 1100
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Cannot be reached 1100
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Cannot be reached 1100
55-Xenon Range -- Status: Cannot be reached 1100
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: Cannot be reached 1100
6D-Trunk Elect. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Cannot be reached 1100
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 731 T HW: 4E0 035 729
Component: Interfacebox H43 3360
Revision: 00000000 Serial number: 303FG057501194
Coding: 0001003
Shop #: WSC 06412 444 53365
VCID: 3365D45352CD7C86565-8066
Subsystem 1 - Part No: 4F0 910 609 B
Component: Bedienteil MMIC6H07 0010
Subsystem 2 - Serial number: 00000000169293
Subsystem 3 - Serial number: 0101.06.050000000100010111ÿ
Subsystem 4 - Serial number: 010111ÿ
No fault code found.
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 S
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000000150137
Coding: 0524582
Shop #: WSC 02327 785 00200
VCID: DBB5DCF31ADD14C62E5-808E
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0013123
Shop #: WSC 02335 785 00200
Subsystem 1 - Component: Fehler Lin-Slave 01
Subsystem 2 - Component: Fehler Lin-Slave 02
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 12
Mileage: 230572 km
Time Indication: 0
Date: 2014.11.04
Time: 06:15:00
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 230572 km
Time Indication: 0
Date: 2014.11.04
Time: 16:43:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7178470
Shop #: WSC 00000 000 00000
VCID: 1C371FEFDF53D3FE67F-8049
1 Fault Found:
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 1
Reset counter: 47
Mileage: 229772 km
Time Indication: 0
Date: 2014.10.30
Time: 16:25:40
Freeze Frame:
Text: 0000B811
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 E HW: 4E0 035 593 A
Component: SDAR
Revision: 0000000 Serial number: AUZ4Z7D80
VCID: 2959363B80013656EC9-807C
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 3
Reset counter: 50
Mileage: 211320 km
Time Indication: 0
Date: 2014.05.09
Time: 21:33:57
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026051430368
Coding: 0002042
Shop #: WSC 02323 785 00200
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0080
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 12
Mileage: 230575 km
Time Indication: 0
Date: 2014.11.04
Time: 06:05:20
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 A HW: 4F0 920 980 N
Component: KOMBIINSTR. M73 H15 0630
Revision: 01000000 Serial number: 4PY352565
Coding: 2129263
Shop #: WSC 06058 444 83892
VCID: 21492E1BF831FE16B49-8074
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 130080622081EF
Coding: ECFE73CD1B7906
Shop #: WSC 08212 444 92469
VCID: 275D300396150026FAD-8072
3 Faults Found:
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 3
Reset counter: 44
Mileage: 227918 km
Time Indication: 0
Date: 2014.10.14
Time: 17:50:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 230575 km
Time Indication: 0
Date: 2014.11.04
Time: 06:05:20
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 12
Mileage: 230575 km
Time Indication: 0
Date: 2014.11.04
Time: 06:05:20
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: E1C9EE1B38B13E16749-80B4
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 12
Mileage: 230572 km
Time Indication: 0
Date: 2014.11.04
Time: 06:05:22
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H45 1100
Revision: 00000000 Serial number: 355BW067562586
VCID: 387FE37F4BAB9FDE637-806D
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000028784
Coding: 0002114
VCID: DEB3D5E709CF01EE49B-808B
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 12
Mileage: 230572 km
Time Indication: 0
Date: 2014.11.04
Time: 06:05:00
Freeze Frame:
Voltage: 12.200 V
Temperature: 21.0°C
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000048484
Shop #: WSC 06108 444 00754
VCID: 23452413E22DEC06A65-8076
Subsystem 1 - Part No: 4F0 915 105 E
Component: von VA0 1506070033
Coding: 344630393135313035452056413031353036303730303333
Shop #: WSC 06412 444 58834
3 Faults Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 51
Reset counter: 32
Mileage: 211394 km
Time Indication: 0
Date: 2014.05.11
Time: 00:24:10
02273 - Quiescent Current Stage 2
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 221428 km
Time Indication: 0
Date: 2014.08.04
Time: 12:56:31
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 12
Mileage: 230575 km
Time Indication: 0
Date: 2014.11.04
Time: 06:05:19
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 HW: 4F0 907 273
Component: Reifendruck 3 H04 0080
Revision: 00040080 Serial number: 00000900006526
Coding: 0062221
Shop #: WSC 02334 785 00200
VCID: E0CFEB1F33BB371E7B7-80B5
Address 6D: Trunk Elect. Labels: Redir Fail!
Part No SW: 4F9 910 591 HW: 4F9 827 851 F
Component: ValeoHeckdeckel H25 0290
Revision: --H25001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: ECD78F2FCF73637ED7F-80B9
Subsystem 1 - Part No: 4F9 910 592
Component: ValeoHeckdeckel H24 0290
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD31.08.07--H24001001C0199ÿ
Subsystem 4 - Serial number: 1C0199ÿ
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 12
Mileage: 230575 km
Time Indication: 0
Date: 2014.11.04
Time: 06:05:20
End ---------------------------------------------------------------------
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 12
Mileage: 230572 km
Time Indication: 0
Date: 2014.11.04
Time: 06:05:00
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 12
Mileage: 230412 km
Time Indication: 0
Date: 2014.11.03
Time: 13:36:00
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 230572 km
Time Indication: 0
Date: 2014.11.04
Time: 06:15:00
Chassis Type: 4F0
Coding: 0001003
Coding: 0524582
Coding: 0013123
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 12
Mileage: 230572 km
Time Indication: 0
Date: 2014.11.04
Time: 06:15:00
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 230572 km
Time Indication: 0
Date: 2014.11.04
Time: 16:43:00
1 Fault Found:
02261 - Data Medium
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 47
Mileage: 229772 km
Time Indication: 0
Date: 2014.10.30
Time: 16:25:40
Freeze Frame:
Text: 0000B811
Component: SDAR
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 50
Mileage: 211320 km
Time Indication: 0
Date: 2014.05.09
Time: 21:33:57
Coding: 0002042
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 12
Mileage: 230575 km
Time Indication: 0
Date: 2014.11.04
Time: 06:05:20
Coding: 2129263
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 44
Mileage: 227918 km
Time Indication: 0
Date: 2014.10.14
Time: 17:50:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 230575 km
Time Indication: 0
Date: 2014.11.04
Time: 06:05:20
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 12
Mileage: 230575 km
Time Indication: 0
Date: 2014.11.04
Time: 06:05:20
Coding: 0082954
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 12
Mileage: 230572 km
Time Indication: 0
Date: 2014.11.04
Time: 06:05:22
Coding: 0002114
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 12
Mileage: 230572 km
Time Indication: 0
Date: 2014.11.04
Time: 06:05:00
Freeze Frame:
Voltage: 12.200 V
Temperature: 21.0°C
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 51
Reset counter: 32
Mileage: 211394 km
Time Indication: 0
Date: 2014.05.11
Time: 00:24:10
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 221428 km
Time Indication: 0
Date: 2014.08.04
Time: 12:56:31
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 12
Mileage: 230575 km
Time Indication: 0
Date: 2014.11.04
Time: 06:05:19
Coding: 0062221
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 12
Mileage: 230575 km
Time Indication: 0
Date: 2014.11.04
Time: 06:05:20
How did the reset went? does these errors came back when you did the reset?
how old is the battery? It seem like it doesn't have enough juice
I just saw this thread now, and this may not be relevant to the original poster, but here is how to remove the key from the ignition:
get a ballpoint pen or other such thin item and insert it into the little hole on the ignition barrel under the key. This will release the lock and allow you to withdraw the key.
Also, this happened to me some months ago. The car would not start when I returned to it and there was zero power. It turned out that the lug mounted on the inside of the boot (trunk) for using the battery to jump start another vehicle had become separated from the body of the car and thus caused a break in the circuit. I have a 2004 3.0tdi quattro tiptronic, (European spec, I live in Ireland) and had fittted new tyres the day before. When the tyre shop was checking the condition of the spare wheel I imagine they bumped the lug off the inside of the boot causing the circuit to be broken. Simple problem, simple solution. The key release thing was new to me as well at the time, I had to call the Audi dealer who instructed me on how to use the pen as described above.
AudiAndy17
A4 (B9 Platform) Discussion
10
01-10-2017 04:47 PM
tubi
A4 (B8 Platform) Discussion
04-20-2008 04:09 AM
