How often do you replace the key fob's battery?
#11
Hi All,
I just owned an used Audi A6 2.0 TDI (2013) one & i did notice the following issue with the remote key (Key fob)!
Every morning from 10th January, 2016 on wards i am not able to UNLOCK the car with the Remote Key . I have to manually unlock the car with key!. Then, i can still start the car with the "Start/Stop" button & drive. Once i drive to my work. Once, i reach work i am able to lock the car with the remote. Also, when i am start from my work (in evening) i can unlock again with the remote as well as lock the car when i reach home. However in the next morning, the same problem repeats!!
Can you please share your experience/expertise on how to resolve this issue?
Appreciate a lot for your support & earliest response.
Thanks & Regards,
Pradeep
Thanks & Regards,
Pradeep
#15
I just bought 06 Audi a6 couple days ago is has Technology package ,push to start,but when i push the button is saying the key not identity ,also i have to push the remote control to open and close the door,i already changed the battery in the key.Whats the problem the key?or other thing?
Thanks
Thanks
#16
Thanks
Thanks
But before you do anything else, did you replace the batteries with good quality (i.e. energizer, Duracell) batteries? If not, do that first, since I changed batteries once with cheap generic ones and they didn't work at all...even though the battery was new. Lastly read the following TSB: http://uberlame.com/a6_tsb/Ignition%...n%20switch.pdf and make sure your actual car battery is good and if it's old and not quite holding a charge get it changed.
#18
hmmm...when you push the start button , do you push it hard and hold it? It does require some force and isn't a real soft touch thing.
#19
When you state your "chip" is broken, what exactly do you mean? Show us a pic.
#20
The car is working with the key and the remote control. But when I hold the key in my hand I can'topen the door I pull the handle 3 times and nothing. I using the remote control is works. When I hold the key and I push the start button 2 times and press the brake I get the massage, "No key identified".
