Last edit by: IB Advertising
- Audi A6 C6 How to Replace Side Marker Bulb<br>Step by step instructions for do-it-yourself repairs.
how to replace side marker bulb?
pull the light housing out from the forward side of it and ti should pop out. Twist the bulb counter clockwise until its free. Pull the bulb out...
by removing the noise damper panel, and then press the clips that hold the housing in-place and push out. Then you remove it as haha bye says.
THanks for the replies.
Is the noise damper panel the plastic piece under the car? The side marker bulb I'm trying to get to in the front passenger side marker.
Haha - the side marker lens is smooth and flush to the car, is there a trick to popping it out?
TIA
TIA
before you pull the housing on the outside of the fender.
since you have to get to it anyway because of a fault code i presume, have to go in through the back i believe.
