Last edit by: IB Advertising
- Audi HVAC Diagnostic<br>Guide to diagnose trouble and recommended solutions.
HVAC Blows very hot air on side vents
#121
im confused how my AC, welll heating works in this car...
now at these winter days, out door in negative Celsius... I keep car in Auto mode all the time... but noticed that even when the engine warms up and im driving, the center vents above the shifter blow practically cold air, side vents mildly warm, but its blowing (or trying to) very strong under windshield... .
when I manually switch to blow in center vents, it blows warm air right away out of those center vents...
is this an Audi philosophy or what the heck, as I tend to keep y hand onthe ****er or armrest, and its being cold as it getting cold air from center vent...
#123
Tried to fix the old unit, is not worth the effort, just buy a new one, i bought one for only 45 euro on eBay.
You will need a flexible hose clamp, or you will go crazy with the three clamps, they are impossible to reach
kelisko (03-01-2021)
#124
First left outer blower got warm, then the right outer blower, after a month the right middle blower only blowed hot air and 2 weeks later the left middle blower got hot. After replacement of the unit all is great again
For 45 euro for the unit and 30 euro for a flexible hose clamp. Took me 30 minutes
#126
Hi Rstoer - Thank you so much for your post. I have just been experiancing this problem for the first time. Seems it only happened on hot days when the temp was above 25C. I have followed your instructions and lets hope all is now fixed :-) Its a pity your photos are not still showing
#127
Like many others, the air conditioning on my 2006 Audi A6 (3.2 V6) was intermittently blowing hot air from the outside vents. By now, the cause of this has been well documented as being a pump valve unit that sits between the rear of the engine and the firewall. According to Audi TSB #2013883-5, changing to an updated unit, with a B added to the original part number (4F1959617[B]) is the recommended fix. They also recommend a set of mounting parts (4F1998617). These parts alone run over $300.
Since mine worked for five years before failing I wondered if it couldn’t be repaired, but I searched all over the internet and couldn’t find anyone who even tried. So I took a shot at it, and YES IT CAN! I’ve been testing the repair for several days now and I’m convinced the problem’s gone. Here’s the best part - it takes less time and effort to repair the existing valve than to replace it. Removing one plug and six T-10 Torx screws is all it takes to disassemble the unit to the point that it can be repaired. The repair consists of cleaning some caked–on substance from the two solenoid plungers and housings. This takes well under an hour and you’ll hardly get your hands dirty. No messing with anti-freeze, hoses, or the like.
Here’s what to do…
Caution: Do this only when the engine is cold so there's no pressure in the cooling system.
Fig 1: Remove the plastic cover between the back of the engine and the firewall (not shown) by lifting the spline from the front edge and gently pulling the cover towards you. With that removed you’ll be able to see the location of the pump valve unit (yellow arrow). One plug and those two little cans are all that have to be removed.
![](http://home.ptd.net/~rstoer/images/1location.jpg)
Fig 2: First remove the rear plug* by placing a small screwdriver where indicated by the green arrow. With the front of the blade under the plastic edge, gently press down. When you hear it click the plug will slide right off. The red arrows on my photo don’t show up too well but you can see the three #10 Torx screws across the front edge. There’s three more across the back. Remove the six screws.
* Update: Someone contacted me to say that he successfully used this method, except he left the coil assembly in the car because he had trouble removing the plug. It's true, the items that require cleaning can be accessed by just removing the six Torx screws. The coil assembly (the yellow and brown item in fig's 4 & 7) can be left in the car, tethered by the wires. Just make sure those two bronze washers (one inside each coil) are accounted for before allowing it to dangle about in the car.![](http://home.ptd.net/~rstoer/images/2removal.jpg)
Fig 3: With the plug and screws removed, lift the two cans and the socket for the plug you just removed as one unit. Wiggle gently if needed, but it should lift off pretty easily. Be careful as one or both of the plungers may come up with the housing, making the plunger springs vulnerable to falling off. The photo shows one plunger & spring still in place.
![](http://home.ptd.net/~rstoer/images/3valvebase.jpg)
Fig 4: This shows all the parts you’ve disassembled. (I took this photo after cleaning everything).
![](http://home.ptd.net/~rstoer/images/4parts.jpg)
Fig 5: This photo shows the solenoid plungers, springs and washers. Note the caked-on substance on the un-cleaned plunger. I found areas of this on both plungers and the brass sleeves the plungers fit in. It’s what causes the sticking, and a good cleaning of these surfaces is all that’s needed to effect a cure. Just make sure you get it all off. I used Meguiar’s Mirror Glaze fine-Cut Cleaner because that’s what I had. Anything similar would work.
Fig 6: On the housing I used a jeweler's screwdriver to gently scrape off most of the sludge, and the Fine-Cut Cleaner on a Q-Tip to get the rest.
Fig 7: Here’s everything cleaned up and ready to be reinstalled. When you reach this point, place the coil assembly right-side up (mine's shown upside-down), and insert a washer into each hole. Then place a solenoid housing over each coil. Finally, slip a spring onto each plunger. The nine parts should now comprise three sub-assemblies.
Fig 8: I found no crud on my valve base but check it and clean as necessary. Insert the plunger/spring assemblies into the valve base (only one is shown in place here). Press each one down and see that it pushes all the way in and springs back freely. Then fit the coil assembly over the plungers, making sure it seats properly on the base. Reinstall the six Torx screws and tighten. Snap the plug back into place on the coil assembly and you're ready to test.
![](http://home.ptd.net/~rstoer/images/8valvebase.jpg)
Assuming all is well, reinstall the plastic cover and spline. That’s it!
Hopefully, this will save someone some money. These cars are expensive enough to maintain (nice to drive though).
Here’s what to do…
![](http://home.ptd.net/~rstoer/images/5plungers.jpg)
![](http://home.ptd.net/~rstoer/images/6housing.jpg)
I can not see pictures in your post. Can you tell me why?
BR,
RDD
9
01-07-2010 07:08 PM
