Instruction to replace Side Light / Daytime Running Light
After hitting a water bottle in the highway, the central console beeps and display the message "Side Light / Daytime Running Light, Left-side". Got home and check, the side light did go out on the driver side.
This side light is the yellow rectangular cover below the head light and above the fog light.
Does someone have instruction how to replace this side light?
Thanks
Thanks
From Bentley Repair Manual:
Release clip - using a screwdriver, insert in the gap/opening towards the center grill and rotate towards the center. Remove air inlet grille at lower part of bumper cover.
Once you have the fog light grille out, you can reach up and push out the holder to access the bulb, or pull the bulb out of the holder and replace.
