Intermittent brake light outage. Help?
I remember reading a thread on this topic a while ago . . . anyone have it bookmarked?
Within the last 3 months, I have had the passenger and driver's side tail/brake light go out for about a day or so, and then it came back. What can I do to remedy this? I have never looked at the light assembly on my '06. Is it a contact/corrosion problem?
Thanks.
Thanks.
No, it's easy to access but not from the trunk. Go in the trunk and look behind where each taillight is and take the extended plastic black fastener off. Once that's off you can literally pop the taillight out as its only held in by clips now.
Just be careful when taking off the black inner cover of each taillight ( where the taillight meets the trunk) off.
Also go in the trunk passenger side cubby hole and push all of the plugs into their respective sockets to make sure one or two are not loose or not in all the way. Wiggle the fuses too.
So I STILL haven't taken it apart and applied dielectric grease. I've been meaning to but haven't made the time yet. Since the lights had been working it was placed on the backburner.
However, this morning I had both the passenger and driver's side brake lights/turn signals go out! First one, then both concurrently! After making some various stops it would even alternate a little as to which one (though it's been mostly the passenger side one) would be out when I started the car back up. Frustrating!
Incidentally, I live in Ohio and the temperature was in the teens this morning when I left.
Taking the lights out and applying dielectric grease is now HIGH on my list today. Ha ha
I really hope I don't have to buy two new assemblies!
Ok. I'm not popping the taillight out as easily as I anticipated. What's the "extended plastic black fastener"? I popped off a relatively large black cap from the liner in the trunk. There's a black "peg" or something (with a slot in it) visible then. However, it doesn't seem to thread out. What am I missing here?
I'm pretty discouraged that I may need to buy TWO new taillights. With this problem being so prevalent, why doesn't Audi make it right by the owners of their cars?
