Intermittent brake light/turn signal issue
My rear passenger brake light/turn signal intermittently goes out. I replaced the bulb as a long shot, but it didn't help. It seems to only go out in the extreme heat, when I've left my car in parked in a lot at 100+ degrees. I don't see the issue in the mornings or at night, just when it's ridiculously hot out. So what's going on here? Do I have a short?
Is it LED or a regular bulbs?
What you should check is the connectors? The ground pin is always an issue. Just clean it by sanding and buying electrical grease to prevent that from happening.
If that doesn't fix the issue then try replacing the unit.
1loveaudi
A6 (C7 Platform) Discussion
06-24-2022 06:21 AM
Whinny
02-23-2013 04:05 AM
Chugmeister
9
08-11-2005 04:00 AM
nw_a4_a4
05-19-2004 05:55 PM
