Jack Stands
#13
If you believe that the specified preload on each fastener is unimportant to withstand the forces that are applied to the joint, then that's your business. However, any mechanic that works at a dealer who did not follow the official repair instructions issued by the OEM would be fired (huge liability you know!). For example, the caliper ribbolt is specified to be tightened to 190 N–m as noted in royclark's thread. If you removed that bolt and didn't re–tightened it to that value and only "snugged" it up, you really believe that would not have an effect on the braking over time? As a licensed, professional mechanical engineer, I am very knowledgeable why a preload, i.e., tightening torque, is specified for bolts in a joint. But do as you wish. For me, I will follow the "guidelines".
#14
Thanks for the info.
I always torque my wheel bolts to the specified 120 Nm. and any other nuts/bolts that I remove.
My son works in an accident repair shop and he tells me that, To comply with British standards approval, torque settings have to be adhered to and all torque wrenches calibrated every six months.
All vehicles have to be logged and what wrench was used.
They have snap inspections and any job can be checked. If torque settings are found to be wrong they can lose their B.S Approval licence.
#15
#16
Nope, both Aud & VW have specified 120 N–m (89 lb–ft) for wheel bolts at least since MY 2000, but probably earlier. My '96 A6 was specified to be tightened to 110 N–m (81 lb–ft).
#17
that figures 120 N-m is 90 ft pounds.. i just dont know how to read the figures and that they needed a conversion
anyone know a good link to a place i can educate myself on this?
^im serious
^im serious
#18
Lol you an engineer, not a technician. and any real technician will tell you its not that important. If it was so critical every other car from every shop everywhere would catastrophically failed. It doesnt and wont. Go back to designing and let the repairing be done by us. yet to hear of ANYBODY getting fired because they dont use torque wrenches on every little bolt on the whole car, how ridiculous and unrealistic. Most places on these cars cant even fit one in to be used. And no i dont think the caliper bolts are that important, tighten them down, be done. Move on to the next thing. Not freak out and make sure its exactly this many ft.lbs omgwtfbbq its one foot pound too much the cars now going to implode lol....
#19
Here is a site to download the best unit conversion tool I have found, "Convert.exe". It will convert anything from US to metric units, metric to US units, or anything in between. This handy desktop tool will eliminate the typical round–off errors that most people do when converting metric numbers to US units.
http://joshmadison.com/convert-for-windows/
#20
"True" mechanics, dont use torque wrenches for stupid **** like that. Its not critical, and is not going to come apart and fail unless you have little flimsy arms that cant tighten things down. its very rare for any REAL mechanic doing it for a living to use a torque wrench for much more than lug bolts and cylinder head bolts, lower intake gaskets on pushrod engines.
Dont fool yourself, specs are there for a guideline not "omg every tech uses a torque wrench for every little bolt on the whole car." There there so dumbasses dont break bolts off or leave wheel lugs loose. Im sure you use a torque wrench on your battery terminals too right lol....
