KevinGary and Dr. Cold's TSB Library
Thanks to Dr. Cold all of my TSBs have been placed in one spot. Perhaps the moderator can make a sticky of this post. Here is the link to the TSBs.
http://www.uberlame.com/a6_tsb/Audi%...TSB%20List.htm
Kevin
Kevin
Forgot to mention
The TSB http://www.uberlame.com/a6_tsb/Headlights%20vibrate.pdf says if no damage found, and adaptive headlamps are affected (which I do have), then refer to TSB 2018787
Anyone know which is 2018787?
Forgot to mention
Forgot to mention
I used the update feature of the Bentley Manual to get the TSB but I still haven't the time to figured out how to copy or make a PDF.....sorry.
If TSB 2015445 doesn't fix the problem then you need to refer to 2018787/2 the latest TSB for vibrating HID headlights, when you take it to Audi refer to the second number.
Here are some pics
Forgot to mention
I just took a look at your list of the TSBs available at the erwin site and it does not list the requested TSB. I have also looked at my internal list of TSB numbers in my database and I also don't have it. If you and I can't find it, it must be hiding in a good spot.
