left bank misfire 3.2 '05
Im having the left bank misfire and im getting codes
p2296
p0346
and also the misfire codes for cylinder 4 5 6 which is the left bank.
I already replaced the left side fuel injection harness which connected to the fuel pressure sensor and also the high pressure pump.
p2296
p0346
Did replacing the fuel injection harness fix your misfires? I am having misfires on all cylinders but don't have any codes and I don't know where to start. Could be several things causing it. Thanks.
Guys, as twopedal suggests, these cars are quite sensitive to spark plugs and coil packs. Look up in your history to see when they were last swapped out.
PO changed plugs about 58k miles ago so mine are due. No clue on when the coil packs were done. Just pulled my plugs and looked at them and they don't look bad. Posted a pic and someone else here agreed with me.
Link to post with pics https://www.audiworld.com/forums/a6-...plugs-2948908/
Of course I can't use "looks" as a definitive measure of the plugs condition. However, I have seen waaaaaay too many posts on here and Audizine where people who were having misfires changed all plugs and all coil packs (and other things) and STILL had misfires. That's why I'm skeptical at just spending $500 to change my coil packs and plugs.
Thanks for your feedback. Any other ideas?
little_e
11-07-2011 01:08 PM
dgkula
02-24-2007 05:33 AM
LarryF_in_Ca
02-27-2005 08:19 PM
petenice00
11-20-2004 08:19 AM
