LIN BACKUP HORN Fault
This won't go away after several DTC resetting, Now its time to hunt it down and see if there's any loose connection. But where is it?? Any ideas? greatly appreciated. By the way my alarm system works just fine; I thought it was related to the Alarm sensors.
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01017827530000
Coding: 4618397
Shop #: WSC 02335 785 00200
VCID: 2E58DD76B9C6576E36F-807B
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
1 Fault Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 78
Coding: 4618397
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 78
Hi. Doing some research i came up to yours thread. Since i have the same error code as you i was wondering if you find the culprit for this error. Thanks i hope i will hear from you
Hello, sorry I hardly check on this forum much (moved on with an A7) but going back to your question, I didn't find the problem. I ended up ignoring it since no systems were getting affected. I traded in my A6 with it 😄.
bballfreak
9
04-14-2019 06:59 PM
