Looking for feedback on k-mac front camber kit
#11
Former Vendor
Have not had any good results with the KMAC. THey don't hold alignment specs well at all and loosen up.
They wear pretty quickly, and when they do you've got to buy them again.
#12
hmmm.. but it appears that they (kmac) are our only option to resolve camber issue at this point. Stern doesn't make the adjustable control arms from the C6.
#13
I have installed Kmacs and so far they work well. No tire wear any more. I've had issue where they got lose, but my mechanic said that he didn't tighten them properly. I didn't notice any improvement in ride quality, and in my opinion I preferred more negative camber. It felt like the car was "more planted" in curves, which negative camber would do i suppose.
To my knowledge kmacs are the ONLY company making camber kits for C6 A6, so good or bad, we are stuck with them.
But I say again, I didn't see any issues, and as previous post said, install them at the same time when you install your springs. It will cut on cost for labor.
#14
Was this just for one car, or how many more?
#15
I am sorry to revive this old thread, but I am wandering if anyone else has issues with K-mac system?
Mine started to make knocking noise when turning the wheel. I jacked up the car and am even able to see the wear on them. The red plastic seems like it is sheering off, and I can see a clear movement of arm over the bushing.... Definitely not too happy.
#16
I have had mine installed for about 10kkm now, so far so good. I have heard that a lot of technique is required to install these, if installed improperly, they go bad fast. A lot of a4 guys run these
#17
#18
It is Funny that you mentioned this now as I am going through the exact same thing. I installed my kit last summer and it has been excellent at keeping a correct camber until two months ago when I started to experience knocking sound coming from the upper suspension area. I checked it out and two of the four kits had come loose. I tighten them and problem went away for a few weeks. Recently the problem has come back and now I also get sound when I cut the wheels either way. Yesterday I took it to my mechanic and again they have come loose plus the rubber has cracked inside on the two that keep loosening up. Another problem is that there is sign of wear in the area that the arms and kit bolts onto. Now I wished I had invested the extra cash on adjustable arms but $260 vs. above $500 for the arms I took a chance with KMacs. I am contacting the vendor to see if I can get replacements under warranty.
You were mentioning that you were considering adjustable arms?! I looked everywhere but could find nothing for our cars. There are some for A4s, but not for A6.
Do you have any more info?
#19
I've heard some creaking from the front, but thats about it.
I did think about putting the OEM springs back instead of the Eibach, but the thought of seeing that huge gap in the front wheel well is frightening.
#20
I see no point in replacing bushings every year. Ends up costing me more than tires...
