Lowering the a6
I want to lower my 4.2 05 a6 at least 1 inch i think the stock height looks silly..my question is will it harm the quattro system any or anything else? and where could i get it done? does the dealership do this?
I have coilovers installed and lowered ~70mm. I haven't had any issues at all with my quattro. You can have the dealer install a set of aftermarket springs and lower you car a little. Dealers tend to be the most expensive place to get maintenance done though.
My '05 3.2Q
My '05 3.2Q
![](http://i6.photobucket.com/albums/y205/NedRager/P1000807.jpg)
lowering also will get bottom of the car close to the road. you will need to be careful driving over speed bumps or you can damage AT oil pan.
A 1 inch below your stock ride height you won't have any different tire wear than you have now. This is assuming you car is aligned properly after the suspension is done.
I've had mine lowered with Einbach springs at a local shop (not dealer, they are way too expensive). I have not had any issues with quattro, tire wear or anything else.
Ride is little firmer, but very tolerable. overall, handling is much better.
Thanks!
These are the ones I used (CP from their website)
PRO-KIT Performance Springs (Set of 4 Springs)
#1 Choice of Automotive Enthusiasts Worldwide!
* High Performance Handling and Aggressive Good Looks
* Lower Center of Gravity
* Stop Quicker, Corner Faster and get Better MPG!*
* Progressive Spring Design for Excellent Ride Quality
* Million-Mile Warranty
The Eibach PRO-KIT is the perfect answer for most frequently-driven street cars. It's our legendary sport spring system that dramatically improves both a vehicle's performance and appearance.
PRO-KIT precisely lowers your car's center of gravity, reducing squat during acceleration, body roll in corners and excessive nose-dive under braking. When combined with Plus-1 or Plus-2 wheels and tires, the Eibach PRO-KIT is the finishing touch to a winning recipe for performance. PRO-KIT also reduces excessive fender-well clearance, making your car look just as hot as it performs.
Every Eibach PRO-KIT is designed and tested by our suspension engineers and performance driving professionals to deliver aggressive good looks and high performance handling, without ever compromising safety or ride quality. By using our proprietary, progressive spring design, PRO-KIT Performance Springs provide the ultimate balance to take your passion for driving to a whole new level.
* Your results may vary. As we have learned from racing and independent testing has proved - lowering your car or truck's ride height also improves your aerodynamic efficiency by forcing more air over the car and less underneath (where most of the drag is found on any vehicle), resulting in higher top speeds on the track and better MPG on the highway.
I added the Eibach springs and while I was there replace the struts with the KONI FSD. I could really feel the difference in handling and the ride compromise with the new struts was a non issue. Go for it, you will be happy. I agree with getting a good independent shop to do it. If you don't know one, ask the service advisor.
